Release Notes | 05-07-2020 | Connect 3D Viewer 1.0.75 & 1.0.76
05-07-2020 11:24
There is a new version of the Trimble Connect 3D Viewer available at  https://3d.connect.trimble.com. Version identifier for this release is: 1.0.76. This release note also covers the release 1.0.75 (May 5th, 2020).
This version update contains fixes and improvements:
  • Road alignment from a LandXML model did not render correctly
  • Workspace API: calling setView API for a big model resulted in operation timeout
  • Workspace API: Hiding all objects did not work properly in some cases
  • Fixed representation of fractional dimensions when using imperial units: leading zero is now displayed (for example: 21’ 0”1/16)
  • Fixed the clash details panel action “Select objects & fit to view”: previously clicking the action caused the viewer to zoom out instead of zooming close to objects
  • Context menu option Zoom to selection did not work properly if selection had objects from multiple models
  • Selecting objects from the content browser data table and colorizing them caused the objects to get hidden
  • Object was missing in a particular IFC model
  • IFC model properties were not displayed in the content browser data table if the property name had a dot in it
  • Workflow Extensions: a property set library was not saved on publish if there were both property and access control related edits at the same time
New Trimble Connect 3D Viewer - Release Summary
