Release Notes | 07-03-2020 | Trimble Connect 3D Viewer 1.0.97
07-03-2020 10:09
Trimble Connect 3D Viewer - Release Notes
Application: Trimble Connect 3D Viewer
Version: 1.0.97
Date: July 03 2020
What’s New
There is a new version of the Trimble Connect 3D Viewer available at  https://3d.connect.trimble.com .Version identifier for this release is: 1.0.97.
This release note also covers releases 1.0.91 (June 9), 1.0.93 (June 16), 1.0.95 (June 26) and 1.0.96 (June 30).
Renewed measurement tool with shortest perpendicular distance mode
  • Note: This feature will become available soon during July)
  • Soon when the point-to-point measurement tool is activated from the toolbar button, it starts by default in the perpendicular measure mode
  • The new measurement mode enables you to quickly determine the shortest perpendicular distances
  • This useful for example when working with rebar models, or when checking for clearances:
Tips for using the new perpendicular measurements:
  • When a dimension is selected, use the TAB key to cycle through the X, Y and Z components
  • When a dimension is selected, use the “D” key to switch directions:
  • When a dimension is saved to a view, it won’t be possible to alter the X/Y/Z and direction choices anymore after the view is loaded
Favorite properties
  • In the properties panel, it is now possible to mark properties as favorite by clicking the star icon. The favorite properties are always displayed at the top
  • Also, now it’s possible to sort the properties panel content alphabetically
  • The panel remembers the marked favorite properties for each user and each project separately
  • Property set notifications
  • When another user edits custom property values, you are immediately notified of the change with an icon next to the property set name
  • By clicking the Refresh button, the updated values become visible in the panel
Bug Fixes
The following items were introduced in the 1.0.95 release:
  • Workspace API:  onPicked event has now the pick normal included
  • Workspace API: added support for generating temporary graphics from custom extensions: addTrimbim(), getTrimbims() & removeTrimbims()
  • Workspace API: fixed an issue where setting alignment with partial properties was not working
  • Fixed an issue where the colorize feature of the content browser data table didn’t fully colorize objects based on custom property set values
  • Fixed an issue where an URL type attachment could not be removed if the URL contained special characters
The following items were introduced in the 1.0.93 release:
  • Fixed an issue where it was not possible to download a model file using a public link created with the “View & Download” option
  • Fixed an issue where it was not possible to delete an attachment that was created using the “Linking Documents to Trimble Connect” component from the Tekla Warehouse
  • Fixed an issue where colors of a rebar model were changed when the content browser data table was opened
  • Fixed an issue where the latest version of an attached document was not displayed
  • Fixed an issue where user could not add a web link to an object
The following items were introduced in the 1.0.91 release:
  • Workspace API: Access token API with permission request was introduced
  • Fixed an issue where adding a .PNG file to ToDo attachments failed
More Information
New Trimble Connect 3D Viewer - Release Summary
#product_updates #release_notes #Trimble_Connect_3D_Viewer
#Release_Notes
