Trimble Connect for Mobile 2.14.1 | Release Notes | Mar 24, 2021
02-26-2021 03:46
Mar 24, 2021
Android | iOS | v2.14.1
Connect for Mobile Android v2.14.1 is now available in Google Play Store and Apple App StoreNEW.
Focus of this release has been introducing the Search in Model feature (that was available in the legacy 3D viewer) and addressing performance issues in the new 3D viewer.
Search in Model
It's now possible to search model elements based on -
  1. Object Property Value (in the 3D model file) or
  2. Combination of Object property Name and Value
Only the model elements matching the search criteria will be shown. This helps to narrow down to model elements of your interest.
Known limitations in Search
  • If search is done with one or more models hidden, the search results will include even hidden model elements. We will address this in next release.
  • Search based on Layer name (when layer name is not part of the file object properties) will not work. It will be handled in future releases.
  • After getting the search results, if any object is selected, the object info panel may not open. De-selecting and selecting model elements again will bring it up. We will address this in next release.
Issue fixes
  • Coordinate View 2 (CV2) Models selection wasn’t possible in v2.14. Its now possible. Please note that for CV2 models with large coordinates , you might need to zoom in closer to the section for selection.
  • Loading of large views caused app crashes earlier. It's now addressed. We have noticed that most of the large views get loaded now. But it might take upto 15 sec (depending on the number of models, size of the view and other factors). Another observation is that if the device’s RAM capacity is below 4GB , the loading of large views will still have issues.   NOTE : Some of the views reported during Beta still have issues. We will be investigating those and addressing in the next release.
Other Known Issues /Limitations
General
  • Slowness is observed while displaying the “Statuses” option in the right dragger of the model viewer screen.
  • Projects list sync progress may be slower, in case of a long list of projects
  • Edit hint text is not displayed for Vertical clip-plane
  • Image attachment from the camera/Gallery is getting rotated 90 degrees after sync.
  • GlobalIds that are received from assimilation does not match between TCM/TCW/TCD. Due to this links created will not be visible across clients for non-Ifc formats.
  • UI in tablets is shown in compatible mode.
  • Revit file assimilation will have issues
  • Layer list may be inconsistent for views shared across Connect clients..
  • Files for which processing is not completed will be shown with empty thumbnails.
  • Quick Access project sync may be sometimes slow when we get back to Project screen
  • Opening Todos have performance issues occasionally.
  • During the first time launch, when we change region, a manual pull to refresh will be needed for list of Projects to display
New 3D Viewer
  • Hide / unhide models (when multiple models are loaded) may show inconsistent behavior occasionally. Unhiding all models again is a workaround.
  • Multiselect object views are not displayed as a selected state for specific devices(iPad)
  • Model alignment values set from other clients are not properly reflected in TCM.
  • Size of the measurement values might be bigger for tablets.
  • Unit settings are not applied (at times) to measurement value.
Views
  • View parity issues exist across Connect clients. These are observed for markups, color, transparency, selection states, orthographic projection and global transparency.
  • Models with more than 2500 object links tend to make the model render slower.
  • Views created using multiple models with show/hide model have issues.. There may be inconsistency when seen in other clients.
  • Views are not deleted from the server even after the associated ToDo is deleted. But users will be able to delete views after detaching from ToDo.
#Release_Notes
#Trimble_Connect_Mobile
#Trimble_Connect
03-23-2021 23:38
Hy  @Tobias Steinhardt
you find the answer here:
https://support.google.com/googleplay/answer/7003180?hl=en
03-07-2021 02:21
I’d like to test the Betas, how do I get access to the TestFlight?
