Trimble Connect for Mobile 2.15.3 | Release Notes | Aug 02, 2021
08-02-2021 03:30
Aug 02, 2021
Android | iOS | v2.15.3
What’s New
Object Elevation
You can now get, set and reset base elevations in Connect for Mobile.
  • Set elevation - Set a new point as base elevation origin. This will help get Base elevation measures with the new reference.
  • Reset elevation - You can undo the action in Set elevation and restore to the actual origin within the 3D model
Learn more here ›
Low memory switch mode
Limit the amount of memory being consumed by this application by enabling this setting.
Please note - this should only be used if you are experiencing issues that result in the application crashing, as it will have an impact on the performance of the application. Though it will prevent crashes, the performance (loading of models) will suffer since no cache will be stored on the device.
Learn more here ›
Bug Fixes
  • Status sharing option wasn’t visible in the 3D Viewer in a few cases. This is addressed now.
  • Hiding and unhiding models had issues with model loading indicator and object links display. These are fixed now.
Known Limitations
Get/Set elevation options are not immediately available upon selecting a model element in a 3D view. The user has to de-select and select the model element again to get the options back. This will be taken up in a future release.
#Trimble_Connect #Release_Notes #Trimble_Connect_Mobile
