Trimble Connect for Mobile 2.20.1 | Release Notes | Aug 08, 2022
07-03-2022 21:49
Aug 08, 2022
iOS | Android | v2.20.1
About this release
Connect for Mobile v2.20.1 is now available in both iOS and Android.
Improvements
IFC Opening Elements
  • You can toggle on/off IFC Opening Elements for 3D models (if the model has such properties).
  • The IFC Opening Element will be shown when the option is checked.
  • When unchecked the opening element will be hidden and you will be able to see the elements covered by it.
Launch .purl type files and views
  • Point cloud file type .purl can now be launched from Connect for Mobile app.
  • Views created from .purl files can also be launched from Connect for Mobile.
  • You will need to be online to launch this file type.
  • The files and views of .purl file type will be launched in Web 3D Viewer.
NOTE
  1. Point cloud files can be added to Connect project only through Connect for Windows (documentation
  2. .PURL format point clouds require using an external potree streaming server. The potree streaming server is not part of Connect.
#Release_Notes
#Trimble_Connect
#Trimble_Connect_Mobile
