Trimble Connect for Revit 1.51.1 | Release Note | December 2, 2021
12-02-2021 08:13
There is a new version of the Trimble Connect for Revit Add-In released today. Version identifier for this release is 1.51.1. The new version is available for download in the Connect apps store page for Revit versions:
  • Revit 2019
  • Revit 2020
  • Revit 2021
  • Revit 2022
This version update contains improvements and fixes:
There is a new setting in the preferences: Export special properties
  • When the new setting is enabled, the following properties will be added in the “Other” property set during the Connect upload process:
    • Family Name
    • Category
    • Rod 1 Inset
    • Rod 2 Inset
    • Standard
Fixed an issue where uploading of the Revit Phases as property set failed if neither the creation, nor the demolition phases were set for an element.
Fixed an issue where a certain model was not viewable in the Connect 3D Viewer after uploading due to a file conversion error.
#Release_Notes
#Trimble_Connect_Revit
