Trimble Connect for Revit 1.91 | Release Notes | August 31, 2023
08-31-2023 00:50
Trimble Connect for Revit 1.91 | Release Notes | August 30th, 2023
A new version of the Trimble Connect for Revit Add-In was released today. The version identifier for this release is 1.91. The new version is available for download on the
Connect apps store page for Revit versions:
  • Revit 2021
  • Revit 2022
  • Revit 2023
  • Revit 2024
This version update contains improvements and fixes:
  • Support for Revit 2024 has been added, and support for Revit 2020 has been removed.
  • The Trimble Connect for Revit add-in can now export connectors, similar to IfcPorts.
  • An issue that caused a connection with a Proxy Server to show as active, while in reality the proxy settings were not used, was resolved.
  • An issue that prevented the notification that a new version is available has been resolved.
  • An issue that caused a security message to show on first Revit startup after installation has been resolved. Revit will now always trust and load the Trimble Connect for Revit add-in.
  • The UI readability on high-resolution displays and/or higher display scaling was improved. Please note that the UI may still not perform perfectly on high-resolution displays and/or higher display scaling
#Release_Notes
#Trimble_Connect_Revit
