Trimble Connect for Revit 2.00 | Release Notes | February 17th, 2025
02-17-2025 04:13
Trimble Connect for Revit 2.00 | Release Notes | February 16, 2025
A new version of the Trimble Connect for Revit Add-In was released today. The version identifier for this release is 2.00. The new version is available for download on the Connect apps store page for Revit versions:
  • Revit 2022
  • Revit 2023
  • Revit 2024
  • Revit 2025
This version update contains improvements and fixes:
  • Introduced a new User Interface across the application.
  • Improvement: You can now create Trimble Connect Folders, straight from the Trimble Connect for Revit Add-in.
  • Improvement: You can now dock the application as a native Revit palette, or use it floating on another screen. You can keep the application running while performing other tasks in Revit.
  • Improvement: Using the Trimble Connect for Revit publisher is now possible across multiple projects opened within one Revit session.
  • Improvement: The progress indication during processing and upload is now more accurate.
  • Improvement: The top menu now includes links to Account Experience, User Guides, Release Notes, and version updates.
  • Added Support for Revit 2025, and deprecated support for Revit 2021.
  • Resolved an issue where the user was prompted with an error stating “No internet connection. Please try again with an internet connection” when the proxy was incorrectly configured. Proxy settings can now be edited at any point in time.
  • Resolved an issue where the application would crash for pods with a very large number of projects.
  • Resolved an issue with the custom Property Set export, where the wrong property from Revit was used. This issue would occur if a parameter was to be renamed in the TRB, whilst that same parameter name was already present in the Revit model.
#Release_Notes
#Trimble_Connect_Revit
