Trimble Connect for Revit 1.40.3 | Release Note | June 5, 2020
06-05-2020 05:18
There is a new version of the Trimble Connect for Revit 2021, 2020 and 2019 add-in available for download at the Trimble Connect Applications page. Version identifier for this release is: 1.40.3
This version update contains new features:
  • Added support for the Revit 2021 version
This version update contains fixes and improvements:
  • Fixed an issue where opening a model resulted to error message "Fail to Use Hard Drive”. This issue occurred when the user opened a central model by detaching it
  • Elevation 3D lines are not exported anymore
  • Fixed an issue where the model was shifted and not-aligned with the correct position. The error happened with large linear models that were away from the coordinate system origin (like infrastructure projects)
  • Added Family Type and Name to the exported properties
  • Changed the names of property sets “GTeam_Quantity_Data” and “GTeam_Identity_Data” to “Trimble Connect Quantity Data” and “Trimble Connect Identity Data” to better communicate their purpose
