Trimble Connect for Windows 1.12 | Release Notes | June 7, 2021
06-07-2021 07:30
There is a new version of the Trimble Connect for Windows application released today. Version identifier for this release is 1.12. The new version is available for download in the Connect apps store page or by clicking the "New version available!" button in the top right corner of the Connect for Windows application.
New Features
  • New sign-in experience provided by the upgraded Trimble Identity
    • Learn more about the benefits and impacts of the upgraded Trimble Identity here
      • Important: All Trimble Connect for Windows installations must be updated to continue using the application after the upgraded Trimble Identity becomes effective
    • Also check out the Sign In & Security help
  • Export to TrimBIM feature now allows exporting the .TRB file directly to a selected folder in the Trimble Connect project
  • Views panel now has a new filter option: All views in project
  • Clicking an URL property value in the properties panel will now launch a web browser directly
Improvements and Fixes
  • Project selection tile layout is improved so that the project name fits in the tile when using the larger user interface controls size setting (the tablet setting)
  • New importer plugin versions:
    • SketchUp Plugin 1.73
      • Fixed an issue where processing of models with capitalized file suffix failed
      • V 1.72: Implemented support for SketchUp 2021.1
    • IFC Plugin 5.60
      • Fixed an issue where colors were not read
      • 5.59: Fixed an issue where IFC file did not work (issue with using bounding box as geometry rep)
      • 5.59: Improved speed while reading large sets of rebars
      • 5.58: Fixed an issue in handling RefereceLine objects
    • DWG Plugin 1.55
      • Fixed an issue where the Organizer group in the Connect for browser 3D Viewer showed incorrect objects linked when the objects are linked from a DWG object selection
      • v 1.54: Fixed an error when processing a certain DWG model
    • LandXML Plugin 1.22
      • Fix vertical profile symmetric parabola for concave curves with positive start gradient and convex curves with negative start gradient
    • Revit Plugin BETA 1.34
      • SDK update
    • Navisworks Plugin BETA 1.17
      • Added better support for units in properties
      • Added missing property types vector3d and color
      • Fixed an issue with the progress counter
      • Improved error logging
      • 1.16:
        • Fixed an issue where file handling failed
        • Fixed an issue where file import stopped at handling invalid material
        • Fixed an issue with hiding hidden object
        • IFC object product types as default layer
        • Fixed an issue with wrong value in layer name
      • 1.15: Improve large file handling
  • Fixed an issue where the user was unable to create or refresh certain clash sets
  • Fixed an issue where View groups that were ungrouped in Connect for Windows were displayed in as empty view groups in the Connect for browser 3D viewer
  • Fixed an issue related to loading previous version of model in 3D
  • Fixed an issue where the Project Admin could not delete views created by other users
  • Fixed an issue in the point clouds tab where adjusting the size setting also affected the density setting
  • Fixed an issue where the grid label '0' was not displayed correctly when viewing a model exported from Tekla Structures
#Release_Notes
#Trimble_Connect_Windows
