Trimble Connect for Windows 1.14 | Release Notes | December 15, 2021
12-15-2021 11:15
There is a new version of the Trimble Connect for Windows application released today. Version identifier for this release is 1.14. The new version is available for download in the Connect apps store page or by clicking the "New version available!" button in the top right corner of the Connect for Windows application.
New Features
  • New unit system added: U.S. Survey Feet. There is a new unit system setting available in Settings → Project
    • Note also: the display precision default values will change to match the selected unit system
  • .TFLX model file format: Now the .TFLX layout point models are converted to 3D locally. This enables viewing .TFLX models in 3D instantly and also in the offline mode.
  • Sort properties alphabetically: It’s now possible to sort property sets and properties alphabetically in the objects panel:
    • The sorting affects both the property sets and the properties in them
    • The application remembers the selected sorting option until restarted
    • Note also the possibility to collapse/expand the property sets by clicking the triangle icon
Improvements and Fixes
  • There is a new dialog that helps to solve possible synchronization problems
    • There will be this new icon visible in the top right corner if the project is experiencing synchronization problems:
    • Clicking the icon will open a dialog that lists the synchronization problems and information that can help to solve the problem:
  • New importer plugin versions:
    • DWG Plugin 1.57
    • DGN Plugin 1.43
    • Navisworks NWD Plugin BETA 1.19
  • Fixed an issue where all model grids were not shown automatically if they were on the same elevation.
#Release_Notes
#Trimble_Connect_Windows
