Trimble Connect Object Manager v1.1 | Release Notes | June 27, 2025
06-27-2025 05:50
Also see the PDF linked below.
New & Improved
This Object Manager release includes these new features and enhancements:
IFC Data
  • New conversion rule configuration - Quadri IFC 4.39 conversion rules are now available for Switzerland.
  • Validation of objects contained in the spatial structure - You can now right-click in the Explorer to validate that all objects are included in the spatial structure at least once, but not multiple times.
For details, see IFC in the help.
Insert
  • Improved import of IfcMaterials - IfcMaterials are now prevented from being duplicated if the same IfcMaterial is imported more than once.
For details, see Insert in the help.
Modify
  • Relation tool enhancements - You can now use different colors for strong and weak relations, and change an existing relation to another relation type.
  • New Automation tool actions
    • You can now create parent and child objects.
    • You can now create IfcElementAssemblies.
    • You can now add IfcMaterial to materials.
    • You can now map a value from CSV with a predefined value (enum/dropdown) when using CSV loop.
    • The functionality for selecting and mapping properties and the display of property names has been improved.
For details, see Modify in the help.
Presentations
  • IFC default presentation rule - You can now use a new, dedicated presentation rule for texture on terrain, road, and railway models.
  • General small enhancements have been made to presentation rules.
For details, see Presentations in the help.
Output
  • New settings option for IFC fi le export - You can now export swept/extruded geometry as BRep geometry.
For details, see Output in the help.
Fixed
This Object Manager release also includes fixes for reported or discovered cases in which:
Explorer
  • The program crashed when creating a new GenericProperty from the Explorer.
Import
  • You could not multi-select fi les from Projects during import.
  • Importing a LandXML fi le set an incorrect elevation for boundaries defi ned with <PntList2D>.
  • When importing IFC 4.3 data, the preview of an imported Spatial Breakdown Structure task was not being shown below the Import task.
  • Miscellaneous other bugs affected the import of IFC fi les.
Output
  • When publishing to 3D, billboard text placement was wrong; 3D presentation tasks had an incorrect Origin.
  • Exporting to IFC2x3 failed the fi rst time.
  • Miscellaneous other bugs aff ected the export of IFC fi les.
Other
Limitations and Known Issues
  • Some swept/extruded geometry in exported IFC-fi les are shown twisted in receiving software. We are investigating if there is an error in the exported IFC fi le or in the receiving software.
  • IFC 4.3 export: Some exported BREP geometries get validation errors in the buildingSMART Validation Service.
  • WFS import is not working properly.
  • Sharing empty relation tasks fails.
1 Files
9 Downloads
Attachment(s)
pdf file
Trimble Connect Object Manager v1.1 Release Notes.pdf   318 KB   1 version
Uploaded - 06-27-2025
