Trimble Connect Sync 2.63.1.0 - Mac | Release Notes | Feb 17, 2022
02-15-2022 01:40
Trimble Connect Sync - Mac - Release Notes
Application: Trimble Connect Sync
Version: 2.63.1.0 | Mac
Date : 17-Feb-2022
Trimble Connect Sync v2.63.1.0 Mac version is now available.
Improvements
Import / Export Project schedules
  • Export / import of schedules will be available for each project.
  • You will now be able to import / export project schedules . This will help you to have the same schedules across multiple machines. Following will be available for export -
  1. Export to Cloud
  2. Export to File
Similarly to import schedules - both import from Cloud or File will be available.
  • Export / Import to/from file can help you share schedules with other project members. This will help them save time on setting up the same schedules set up by one project member on their machine.
  • Duplicate schedules : In case the schedules being imported already exist, you will be given the option to retain the existing one or replace with the new one.
NOTE :
  1. The Export option will not be available where a project has only one schedule.
  2. When there are multiple schedules with the same name for a project, the user will be given the option to choose the desired schedule.
#Release_Notes
#Trimble_Connect
#Trimble_Connect_Sync
