Trimble Connect Sync 2.63.1.0 | Release Notes | Feb 8, 2022
02-04-2022 00:02
Trimble Connect Sync - Release Notes
Application: Trimble Connect Sync
Version: 2.63.1.0 | Windows
Date: Feb 08, 2022
Trimble Connect Sync v2.63.1.0  for Windows is now available.
Improvements
Import / Export Project schedules
  • Export / import of schedules will be available for each project.
  • You will now be able to import / export project schedules . This will help you to have the same schedules across multiple machines. Following will be available for export -
           1. Export to cloud
           2. Export to file
Similarly to import schedules - both import from Cloud or File will be available.
  • Export / Import to/from file can help you share schedules with other project members. This will save their time. They will not have to set up the same schedules again.
  • Duplicate schedules : In case the schedules being imported already exist, you will be given the option to retain the existing one or replace with the new one.
    NOTE :
    1. The Export option will not be available where a project has only one schedule.
    2. When there are multiple schedules with the same name for a project, the user will be given the option to choose the desired schedule.
#Release_Notes
#Trimble_Connect
#Trimble_Connect_Sync
03-25-2022 04:03
Unfortunately update install crashes (silently) due to unhandled Exception:
Anwendung: Trimble.Connect.SyncTool.exe
Frameworkversion: v4.0.30319
Beschreibung: Der Prozess wurde aufgrund einer unbehandelten Ausnahme beendet.
Ausnahmeinformationen: System.ComponentModel.Win32Exception
bei System.Diagnostics.Process.StartWithShellExecuteEx(System.Diagnostics.ProcessStartInfo)
bei System.Diagnostics.Process.Start(System.Diagnostics.ProcessStartInfo)
bei Trimble.Connect.SyncTool.ShellViewModel+<>c__DisplayClass151_1.<NewApplicationFound>b__1(Prism.Interactivity.InteractionRequest.Confirmation)
bei Trimble.Connect.SyncTool.Core.Interactivity.CommonDialogAction+<>c__DisplayClass47_4.<Invoke>b__1(System.Object, System.EventArgs)
bei System.Windows.Window.OnClosed(System.EventArgs)
bei System.Windows.Window.WmDestroy()
bei System.Windows.Window.WindowFilterMessage(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
bei System.Windows.Interop.HwndSource.PublicHooksFilterMessage(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
bei MS.Win32.HwndWrapper.WndProc(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
bei MS.Win32.HwndSubclass.DispatcherCallbackOperation(System.Object)
bei System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate, System.Object, Int32)
bei System.Windows.Threading.ExceptionWrapper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate)
bei System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32)
bei MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr)
Is there a workaround?
02-09-2022 01:46
after this update some users in my company are not allowed to sync anymore . Help needed
02-08-2022 15:25
is Live Sync on the roeadmap of Trimble connect sync like onedriver sync und BIM360
