Application: Trimble Connect Sync
Version: 2.69.1.0 | Windows
Date: Dec 01, 2023
Trimble Connect Sync v2.69.1.0 is available.
Optimized logic to reduce load on Connect server due to sync operations.
Added analytics to track app usage to find opportunities for improvement.
There were issues with Download Only sync where local files weren’t overwritten. This is addressed now. NOTE :If server side file is modified (and conflict resolution logic is set to Files in Connect will override local files) and the local file is also changed, then the server side file will overwrite the local file.
#Release_Notes
