Trimble Connect Visualizer
03-20-2019 23:06
Overview
The Visualizer helps customers to build compelling sales and project presentations. The Visualizer enhances presentations with compelling, descriptive content that demonstrate design and build options and clearly communicate the structural strategy for feedback from the widest stakeholder audience to drive productivity and project quality gains.
  • The Visualizer uses Unity 3D game engine.
  • The Visualizer enables visualization of native Tekla Structures parts and bolts and allows an opportunity to map materials between a Tekla Structures material and a Visualizer material
  • Features
    A. Tekla Structures
    To render a scene, first decide if you wish to render all or part of the model.
    Visualize all
    • Double click this icon and this will render all parts of the model, regardless of if they are visible or not.
    • Reinforcing will not be rendered in the current version of Visualizer
    • Visualizer selected
      • Only selected items will be rendered
The Visualizer comes with a built-in material library. These materials cannot be created or edited. The currently available materials in the visualizer catalog are:
You cannot add more materials to the visualizer library.
When you begin to render with Visualizer from Tekla Structures, visualizer will attempt to automatically map the Tekla Structures materials to Visualizer material catalog.
However, if you wish to change or correct this mappin, this can be done using the Visualizer material type mapping
The Name column contains materials which are found in the current model.
They Type column is where you map to a Visualizer material by selecting and dropping down the cell.
When the ‘All’ box is ticked, all materials which have been mapped in projects other than the project currently open, are displayed. This can help you compare how you may have mapped a material on another occasion.
B.Visualizer - Trimble Connect Visualizer
The same render application used in this Tekla Structures extension is available in Trimble Connect. Use the Trimble Connect Visualizer to visualize models in Trimble Connect:
  • First download and install Trimble Connect for Windows
  • Then download and install Trimble Connect Visualizer
  • Launch Trimble Connect Visualizer by clicking the button in the Models panel (Note: the button is visible only to users with Business or Business Premium subscriptions)
C. The Visualizer has following options and functionalities
   Open Environment controls (Sky box, Sun, Ground)
   Take snapshot of the rendered screen
   Open Snapshot directory (Pictures\TrimbleConnectVisualizer)
   Full screen/Exit full screen (F11)
   Zoom Original
   Open Views and fly path controls
   Full screen (Hide/Show controls)
a) Skybox
It is possible to choose skybox which is shown in the background of the model.You may also create your own skyboxes by adding a 360 degree photo (PNG or JPG with 2:1 aspect ratio) to file location - ..Pictures\TrimbleConnectVisualizer\Skyboxes.
The aspect ratio must be 2:1 (e.g. 1000 pixels by 2000 pixels) otherwise it will not load correctly into visualizer.
b) Sun controls
Rotate the sky around 360 degrees. Notice, that you need to have a sky picture selected to see difference.
c) Ground
Ground level
d) Views and fly path
It is possible to create predefined views that can also be used as a fly path by setting way points
Way points are created by picking + and removed by clicking x. Tekla Structures model specific fly path way points are stored for visualizer future usage. Separate settings for full/All visualizing and selected visualizing.
          Play , Stop separate
Total length of fly path animation in seconds
      Toggle repeat
   Animate sun position toggle
05-29-2026 08:34
Snapshot does not show background skybox image
2331161091@ut.edu.vn
tungudc85@gmail.com
09-27-2023 02:25
how can i use the mapping in Trimble Connect for Windows?
02-02-2021 05:31
Hello, The visualizer button is not showing in trimble connect. has this been removed?
