Trimble Connect Visualizer Release Note - June 7, 2021
06-07-2021 07:46
There is a new version of the Trimble Connect Visualizer application released today. The new version is available for download in the Connect apps store page
New Features
  • Advanced graphics settings panel:
Improvements and Fixes
  • Added translations
  • Made en-us as a fallback language in case selected lang is not found.
  • Changed CRLF to LF in sync protocol for macOS support
  • Fixed macOS localization loading.
  • Increased responsiveness of pinch zoom.
  • Improved touch for spatially large models.
  • Shadow distance is determined by model size
  • Improved touch support
  • Pinch zoom initial implementation.
  • Touch pan initial version.
  • Improved the camera upside down logic.
  • Double click to place sun on the sky, Improved water shader and other aspects of water
  • Small tweak to water reflection. When taking a screenshot 16k shadows and higher quality pcss light settings are now used. Default shadow distance reduced to 500.
  • Added support for DDS format skyboxes. Considerably faster to load and uses less memory.
  • Fixed walk (gravity) mode so that walking speed
  • Fixed default for shadow sharpness
  • Changed default shadow softness from 4 to 2
  • Changed shadow distance to 500.
  • Added localization of tweak panel texts.
  • Added tweak menu strings to xaml.
  • Added support for TMPro text localization
  • Load skyboxes only after skybox dialog is visible. This reduces startup mem usage considerably.
  • Shadow setting tweaks
  • Update camera data every time if something changes on the server since the user might touch the camera in TCV and all parms won't update from the server if not changed
  • Enable -p command line option to define sync server port.
  • Sync screen capture camera fov with main camera fov
#Release_Notes
#Trimble_Connect_Visualizer
