MOUS_ICO Menu: Tunnel > Tunnel Project Settings…MOUS_ICO Toolbar: Tunnel: Tunnel Project Settings…
This is the dialog where set up your tunnel project. Most of the functionality in Novapoint Tunnel uses the project information you specify in this dialog.
The tunnel project file holds the information of which tunnel geometry file that should be used together with a road project and a terrain model.
This dialog doesnít read the project setup from the general project ID in Novapoint, so you have to set up your project from scratch in this dialog.
The following tool-buttons are available in this dialog:
