Novapoint Road Library
Turnaround
04-19-2021 14:56
This function design turnaround and draw the same to AutoCAD.
  • The resulted turnaround will be a 2D drawing.
  • Elevations to the 2D Turnaround drawing can be defined using the Elevation Tools.
MOUS_ICO Toolbar: Not available from the Toolbar
MOUS_ICO Menu: Road > Intersection Tools > Turnaround…
Command prompt for:
Pick first edge line:
Pick second edge line:
A preview of the turnaround will be drawn on AutoCAD with the default values.
  • The preview will be updated instantaneously when the parameters are modified in the dialog.
  • The unit of linear measurement and angular measurement are meters and decimal degrees, respectively.
  • A preview of the active type of turnaround and the parameters are represented at the lower right corner of the dialog.
Type of Turnaround
The pull-down menu lists all types of turnarounds available.
  • The parameters of the selected type are graphically illustrated at the lower right corner of the dialog.
