Novapoint Road Library
Update Road Model Cross-Sections
04-19-2021 13:01
Use this function to update the cross-sections (drawn using Draw Cross-sections from Road Design Task), if the road model has changed.
MOUS_ICO Toolbar: Not available from the Toolbar
MOUS_ICO Menu: Road > Draw Cross-sections > Update Road Model Cross-sections
Command prompts for:
Select cross-sections:
Select Objects:
MOUS_ICO Select the nodes of the cross-sections. The node is a circle with radius 1 units at the insertion point of the cross-sections.
Tip:
  • Use the selection options Window of CAD to select the node at the insertion point.
The existing information of the cross-sections will be displayed on the dialog Existing Information. Use the button Update to update the cross-sections.
