Novapoint Road Library
Vehicle Symbols
04-20-2021 05:34
Use this function to insert illustration symbols.
  • Pre-defined vehicle symbols (AutoCAD drawing blocks) can be inserted using this function.
MOUS_ICO Toolbar: Tools: Vehicle Symbols
MOUS_ICO Menu: Road > Tools > Vehicle Symbols
The dialog 'Vehicle' will pop up.
  • The left pane of the dialog lists all the symbols available and the right pane holds the preview of the symbols.
  • To insert a symbol highlight the desired symbol either from the left pane or right pane and click 'OK'.
  • You can also double-click on the symbol name (right pane) or the preview to insert.
Command Prompts for:
Fetching 'F-PARSBG' (is already defined in the drawing).
The name of the symbol selected will be displayed at the command prompt. Command prompt also mentions whether the symbol is defined or not.
_INSERT Enter block name or [?]: F-PARSBG Specify insertion point or [Scale/X/Y/Z/Rotate/PScale/PX/PY/PZ/PRotate]:
Command Option Command prompt Prompt Answer
Scale Specify scale factor for XYZ axes: Enter the overall scale factor.
X Specify X scale factor: Enter the x-direction scale factor.
Y Specify Y scale factor: Enter the y-direction scale factor.
Z Specify Z scale factor: Enter the z-direction scale factor.
Rotate Specify rotation angle <0.00>: Enter the numeric value for the angle at the command prompt or pick the rotation angle from the screen by moving the mouse.
PScale Specify preview scale factor for XYZ axes: Enter the over scale factor for the preview of the symbol.
PX Specify preview X scale factor: Enter the x-scale factor for the preview of the symbol.
PY Specify preview Y scale factor: Enter the y-scale factor for the preview of the symbol.
PZ Specify preview Z scale factor: Enter the z-scale factor for the preview of the symbol.
PRotate Specify preview rotation angle: Enter the numeric value for the angle at the command prompt or pick the rotation angle from the screen by moving the mouse.
