Vertex Marker
04-12-2021 16:44
Vertex Marker
What
Here you set data for marking of vertices in the profile part of the longitudinal profile drawing. This includes layer name in the drawing, color, and line type, with which text style vertices are to be drawn, from which file the text style is gotten, possible text prefix for the name, and the number of decimals in the station number.
  • Vertices are not drawn unless the check box for “Draw Vertices” is marked under Longitudinal Profile.
Where
The function is run from the following locations:
