Use this function to obtain a list of details (Chainage, Northing, Easting, Elevation, Radius, and Slope) at desired chainage of an alignment. The function lists the details at the desired chainage of the active (selected) alignment.
This function works only on the alignments saved in the database (Quadri model).
The active alignment can be changed without closing the dialog, facilitating the study of the details of the other alignment.
The details can be saved to a text file.
The function also inserts a label at the selected chainage. The label consists of chainage, elevation, and slope value.
The label can be customized for orientation of label, offset of annotation from leader line, font, numeric value style, and accuracy.
Procedure
MOUS_ICO
Toolbar: Alignment Analysis:
Vertical Information along Alignment
MOUS_ICO
Menu: Road > Alignment Analysis > Vertical Information along Alignment…
Tip: This function can also be activated from the function
Object Menu (NCO). By default, the selected object will be the active alignment.
Command prompts for:
Pick Quadri alignment object:
MOUS_ICO Select the alignment for which the above said details are required.
The dialog box Alignment Info - will pop up, with the details of the selected alignment and the location of the cursor. A cross wire appears on the alignment which follows the mouse movements. Pick the chainage, at which the details are desired. Alternatively, key in the desired chainage in the edit field Chainage.
To select another chainage:
Mark the check box Draw Slope Value to have the slope value as well including chainage, Northing, Easting, elevation, and radius in the text file.
Mark the check box Save mark data to file to save the details to a text file.
The location of the file can be specified with the ellipse button
The file can be viewed with the preview button
Mark Setup
Use this button to configure the label for Chainage, Elevation, and Slope Value. The dialog box Text Setup will pop up.
For further details, refer
to the Text Setup below.
Pick Alignment
Use this button to change the active alignment. Pick the alignment from the drawing (follow command prompt)
Draw
The function inserts the label at the selected chainage. The label is a leader line with the details Chainage, Elevation, and Slope Value.
Text Setup
Configures the set-up for the text. Parameters that can be configured are Text angle, Text Distance, Font, Number Format for Chainage, Number Format for Level and representation of Slope among Ratio/Percent/Per Thousand.
Text is placed along with a leader line.
Note:
Some of the options (Text angle, Slope, etc.,) may be disabled depending on the location from where the dialog Text Setup is called.
Text angle
The orientation of the leader line and the text is defined at this field.
Text Distance from arrow (m)
The offset of the text from the leader line. A positive numeric value place the text above the leader line and a negative numeric value places the text below the leader line. Enter the desired distance with the proper sign at the field Text distance from arrow (m).
Fonts
The desired font for the text can be selected for the dialog box Fonts which pop up with the key Font. The dialog Fonts will pop up.
Predefined fonts can be selected from this dialog box. The dialog box can be activated from various functions of Novapoint.
If the predefined font style does not fit the requirement, create a new font using the button Create new font.
The fields, Style Name, Text height, Color, Font file, and Save Changes will be activated once the new font is created.
The standard dialog box Select Color will pop up with the button Select Font Color or the color field adjacent to the button.
To select the font file (SHX) click the button Select Font File and browse to the file location.
Text Format
Chainage Number Definition and Level Number Definition allow you to define how the numeric values are to be written. The dialog Number Definition will pop up.
Number Definition
The number definition allows the user to define how the numeric values are to be written. The following setting can be configured.
Number of decimal places
Unit of measurement among meter, centimeter, and millimeter.
Rounding off the value
Fixed number of decimals (trailing zero)
Leading zero
Using a split text
Position of split text
Character of split text
Prefix
Suffix
The dialog box Number definition is having three tabs, General, Splitting, and Extra text. The dialog box has a graphics area in which the parameter, entities will be displayed. The parameters are updated in the graphic area simultaneously for the amendments made if any.
Show slope as
Slope can be represented in three forms, As Ratio (1:S), As Percentage, and Per Thousand. Mark the desired radio button.
