Trimble Connect for Browser 2.39 | Release Notes | March 10 2016
12-20-2016 19:52
New Features
  • User interface performance improvements
  • Project home page filter
  • Public API to query BIM objects
  • View 3D button in detail viewer for DWG files
Improvements
  • Change behavior of 'move file/folder'
  • Revit Plugin - Project listing now shows Read-Only/No Access Folders
  • Export ToDo To Excel now includes assignee Column
Fixes
  • Invite window freezes when try to invite a user
  • ‘Get’  API is called for deleted project
  • File/folder - "Last modified by" is updated in the middle panel and not in the right panel
  • File activity history takes one minute or more to load
  • Dialog box stuck on 'Working' when changing admin to user
  • Deleting a file is increasing the No. of Revisions on the project details page.
  • User - changing from admin to user throws timeout exception
  • Views - clear selection link is shown even after deselecting all the views in left panel
  • User is able to see the deleted todos comment in the 3D viewer
  • Thumbnail shows missing objects not shown in 3D viewer
  • Revit Plugin - Revit file shows incorrect geometry
  • Clashes created through APIs get stuck at 1% if files are not assimilated by the time clash is created
  • Activation mail not received from TC for the project invite users after token expiry time
  • "Last modified on" column disappears after renaming folder/file name
  • Filter -  Date filter is set from previous project but activities are not filtered
  • User is not able to create view, blank error is getting displayed
  • Deleted clashsets are visible under clashset accordion.
  • Second invite e-mail contains project lInk instead of sign-up link
  • User is able to restore the folder
  • Improper error message is seen when user(read only access) try to checkin the file
  • Activities which are not related to particular object is seen in right panel activities
  • Special character star(*) is accepted in name when editing the clashset created.
  • Switching the tabs hides the right-side panel of a selected TODO task
  • Clashset - Deleted clashset is not removed from clashset grid when trying to access after deletion
  • Views and Clashset : No error message is getting displayed when we try to change shared with field for a deleted clashset/view
  • TODO tab - ASSIGNEE column in TODO table is not active for ordering list items
  • Todo - Selected todo is not displayed in the right panel, when we navigate to other page and come back to ToDo page
  • Last visited by column does not get updated when in list view.
  • No space between comments textbox and border on hovering to edit.
  • Todo:clicking on thumbnail is open in 3d viewer and View accordion is highlighted
  • File move causes last two revision's time stamp to be changed
  • Models disappear while moving around on 3d viewer and affects user experience
  • Sorting is not working correctly for last modified by column
  • Revit file errors on upload
  • After creating new project for ASIA project details are not cleared for new project
  • Edited project name in project details page is not saved
  • Unable to invite an active user to project
  • Number of files and size values are not updated after uploading and deleting multiple files
  • ifczip processing improvements
  • Renaming processing file causes error "File is still being processed ..."
  • Revisions list clicking on file name does not open viewer
  • Clicking on search View results do not open View in 3D viewer
  • Newly created project is not seen as the first project
  • Recipients property is missing when listing releases
  • Public v2.0 APIs : Folder creation fails under root folder for all members in the project other than project creator
  • Clash processing status is not shown in 3d viewer right panel
  • Wrong creator timestamp on file restored using v2 File upload API
  • Invite to new user is not sending emails
  • Home page - Last Modified column is displayed Blank
  • Opening LandXml files bring up 2D viewer instead of getting opened in 3D viewer
  • Update Group object to add standard fields
  • User should be able to create/edit a Clashset with name using , (comma).
  • Alignment not ready right after model is uploaded
  • Inviting users second time are not seen in Team page in Asia pod.
  • List comment public v1.0 API is throwing null pointer exception when objectId is not given
  • Folder Checkout: User having Read only access for folder wrong message display while checkout
  • Scaling is not displaying any error message if less than minimum value is entered
  • Admin User not able to create a folder in Data page.
  • In Firefox ,alphanumeric characters should not be allowed in the alignment settings text fields
  • 3D Camera views button get hidden when selecting Toggle pane view & Add measurement buttons.
  • Search results shows the projects created with EU and ASIA locations, but unable to open these projects
  • 3D Clicking on Hide button does not hide all the models
  • 3D Values provided in the Alignment are only reflected for the first model not for the rest.
