Trimble Connect for Browser 2.40 | Release Notes | June 01 2016
12-20-2016 19:35
New Features
  • Import new or update existing ToDo's from excel
  • Import new or update existing ToDo's from BCF 2.0 (beta feature)
  • Export ToDo's to BCF 2.0 (beta feature)
    Import new or update existing project members and groups from excel
  • Easy access to user profile through a new Public API.
  • Show "Create Release" option in "Add files to Release"
  • API: Implementation for Set/ update folder permissions (Admin only)
  • ToDo API: Completion progress field
Improvements
  • Search results should show the counts
  • Comment box can be on top; as user has to scroll all the way down to enter new comments
  • Activity for a view added to ToDo
  • Release/Todo due date changes after creation - Date component should handle without timezone.
  • API to serve thumbnail with auth token
Fixes
  • 3D viewer toolbar is not persistent across full screen toggle.
  • Firefox 37.0.1 - Markups - User is not able to insert Text Markups.
  • Snapshot doesn't visible after selecting from grid.
  • Snapshot - Not able to view the list of users in the autocompete dropdown.
  • 3Dviewer: Left Panel: Clicking on hide icon takes the scroll bar to the top
  • Todo : Clash Item image should not be shown in both thumbnail and attachment
  • Snapshot : Snapshot created by user is seen in "shared with me" section for admin
  • snapshot : "Select snapshot to update" message is not popping up when trying to update snapshot without selecting anything
  • ToDo shows selected and details of uploaded file are seen in right panel.
  • When user creating view from the 3d page creating button is not working as expected
  • Checkout File API:user is able to checkout or checkin same file multiple times
  • Views , ClashSets, Releases : Edit comments in Data Page : While entering more than 1024 characters, error is not thrown
  • Clicking on the create release the due date textbox is getting highlighted in red colour for error
  • Clashset : User is able to view admin clashes
  • Projects : Only 100 projects are listing in webapp
  • When a folder is moved, the child files/folders path are still referring old path
  • View disappears from center panel but the right panel with details are still visible
  • Project name on creation is truncated if more than 255 characters
  • APIV2 - PERMISSION_DENIED error is generated upon view group creation , while creating with old View IDs
  • No error thrown for corrupt project image
  • Approximate values seen for tolerance/clearance distance for some values
  • IE - Folder Permissions doesnt work
  • IE - Names doesnt autosuggest when applyin group to user
  • Refresh issue: Wrong user status shown in user details page
  • Last accessed date of a project in dashboard shows as empty though it is accessed. User Joined project Activity is also missing
  • If file is renamed, old file name is shown in 3D Viewer Model Tree
  • Team - Wrong message displayed when try to filter by status
  • FBX file gets stuck at 1% assimilation
  • Non-project admin can see email settings enabled as a site admin
  • User is NOT able to upload multiple files in the project getting Error {"message":"INVALID_NAME","error code":"INVALID_NAME"}
  • Invalid Tool Tip Position When 2D File Opened
  • Todo - New todo from mashup not listed in todo from 3D viewer
  • Project name with numbers fails on edit
  • Activity not ordered properly
  • Project loading icon misaligned for LIST view display
  • Incorrect alert context
  • Folder:In right panel Validation Error box is retained on switching tabs
  • Non-Master POD : Data Page: Views, Clashes:  Opening views/clashes from data page open up the model in Model Tree instead of View/Clash accordian
  • Incorrect Alert message is displayed while creating a Group with Certain Special char.
  • Clean up permission field in Search private API
  • Todo : Right panel details of selected todo get collapsed with properties panel for few seconds
  • In IE -white stripe appears on the 2d viewer.
  • Data : Sorting not happening correctly for last modified by column in data explorer tab
  • tofu model : thumbnail has fine lines which was not there earlier
  • Created todo from selected snapshot does not get listed in todo on 3D page
  • Http status 500 error is thrown for the Open release files.
  • ToDo: While creating a ToDo, Assignee search results are inconsistent
  • TODO: Right panel Assignee text box improper functioning
  • Recent project selection is not updated in project page when clicking it first time.
  • Export to Excel : Exporting to excel by renaming a folder downloads empty excel
  • TODO tab: the Date value in Date filter is partially hidden
  • User cannot select a clashset from a list
  • 'snapshots' appears in URL
  • mashup does not work in angular UI.
  • Site admin : Sorting is not happening correctly for createdOn and email columns
  • No clash detection when two models are mashed up and one of them is offsetted
  • Todo - Attachments are not getting displayed in 3D Viewer
  • Error while creating a folder
  • Activity thumbnail is not revision specific
  • New Project: Date picker left and right arrow buttons are not working correctly
  • Todo - User should NOT see all the thumbnails of the attachments in the right panel
  • Folder v2 API automated test - consolidated buglist
  • Upload : Cannot upload 0KB XML files
  • Activity and Due Date for release is not working as expected
  • f3d translation issue with geometry transformation
  • Public API : Patched folder cannot be deleted
  • User is not able to checkout folder containing files after deleting and restoring the already checked out, checked in folder
  • Viewer is not getting updated when the todo is created with view
  • Firefox -  User is not able to see the edit user access button in the right concer of the User details page
  • Date filter:On home page wrong message display  "There are no projects Create a new ToDo here"
  • Activity & due date for release not working as expected
  • Data Page is not highlighted when the project details page is on.
  • TODO- Right pane- Tooltip missing for Remove attachments
  • User names are hidden in tool tip while hovering in the left panel
  • Release: Save button looks disabled when single valid character is provided.
  • Object count inconsistent for IfcDoor and IfcWindow in TOFU in quantity take of report compared to BIMData API
  • User Invite Does Not Get Sent Out
  • Folder permission dialog gets stuck when we remove permission for a user
  • When user trying to add to group getting error The user you are trying to add in group is not in the project"
  • Even though user is not removed from project the count from the group decreases and user gets removed from group
  • Views : 'No views' message is not seen while filtering
  • Project creation dialog does not have a default choice for POD
  • Home page - Projects are NOT getting listed if user is having 350+ projects.
  • 3D view is blank when using French Regional Settings Error
  • Data Page : When a deleted file is uploaded again, it gets selected automatically
  • Public v2.0 API : ToDos - Create Todo api issues found during automation
  • Join company pop-up continues to show after confirmation
  • Clicking on Trimble Connect logo on Compliance/Profile page directs user to Projects page
  • Recipient of released file can not see the file in explorer if permission has been changed to no access
  • Groups API : Removed user is able to view "groups list in a project", "users list in a group", "group details"
  • Todo attachment - Embedded view model name is missing
  • 'Submit' Button Does Not Work When Removing Custom Permissions
  • LandXML Files Do Not Assim If Uploaded via Sync
  • Click on a project refresh project list instead of navigate to the project
  • Store page is seen for few seconds while hitting its URL without signin
  • Assimilation fails with "Error processing data for Viewer"
  • Missing property in F3d from Revit
  • Releases are getting created on clicking shared with information symbol.
  • Z-Fighting issue for sketchup models
  • Not seeing checkbox checked on Terms and Conditions in Profile creation page
  • 3D viewer- Model Tree-Alignment settings- Positioning with metric 'cm' is behaving weird
  • Releases-Release name should not accept more than 255 characters and should be truncated to 255 characters
  • 3D viewer- Alignment Settings- Clicking Reset after modifying the value doesn't return previous alignment position
  • 3D viewer- Tool bar- Clicking on the 3D viewer tools(with dropdown) highlights the tool by turning its background white
  • 3D viewer- Toolbar- Section pane is not turning off when measurement tool is in use
  • Team&Profile- On clicking details of mailinator user in Team page, it naivigates to Projects page
  • 3D viewer- Toolbar- The Dropdown list stays as such even after selecting one
  • Reports : Quantity take off tab is seen empty till the values are populated
  • Search Filter : System/Project wide search date filter 'To Date' lists wrong results
  • Search : Query length error handling missing in system/project wide search
  • 3D viewer- Toolbars- 'Markup' in Toggle type visibility shows hide eye icon though markup tool is selected
  • Release : Mail notification is not received for recipients when notes is not specified
  • 3D viewer- Left modules- Model tree displays alignment settings when switched back from other components(TODO/Views/Reports..)
  • 3D model visualization issues
  • 3D viewer can't open multiple 3D files on FireFox
  • Assimilation progress field is seen in right panel for assimilated file
  • Hidden/Selected elements are not applied in view front end
  • 3D viewer- Tool bars- Section plane tool performs both section plane and add measurement
  • "Project Not Found" error message is seen while clicking any project
  • Implicit view missing in todo attachment (specific case)
  • ToDo: Whole page is getting hide except viewer in IE(11) after clicking on create ToDo tab
  • Non master pod invite is not showing as pending activation
  • POD Filter is broken
  • New users are not able Signup successfully, when the emailId contains + symbol
  • When Folder is Deleted and Recreated Manually, it Does Not Link to Previous History
  • Public v2.0 APIs : Response of View User Details API is missing company domains & createdOn attributes
  • Export team to excel is broken
  • Todo : "Internal error occurred" message is seen while updating todo details when due date is empty
  • 2d Viewer : File name is missing in upload file dialog
  • ToDo : Due date can't be set with null values. Getting Null pointer Exception.
  • Clash created on a renamed 3D file does not get picked up by worker
  • Public v2.0 API: ToDos - Allowed to add View from one Project to todo in another project
  • Upload error - org.hibernate.exception.LockAcquisitionException
  • Commerce: Profile / Compliance page: country list missing countries
  • 2D Files Fail To Assimilate
  • Status for 2D Files not Correct When Processing has Failed
  • button in the schedules
  • Newly Signed up user not able to login . Getting org.hibernate.NonUniqueResultException
  • Home Page:observe Non Unique result Exception
  • Activity : When due date for a Todo is edited in a Project, Activity page is broken with NumberFormatException
  • Removing User(s) from Group Causes application lock
  • Clash Item image should not be shown in both thumbnail and attachment
