View Entry
Back to Library
Trimble Connect for Browser 2.41 | Release Notes | September 8, 2016
Recommend
12-20-2016 19:12
Content Manager
New Features
View .skp models using our new native SketchUp model viewer without leaving your browser
Support for Internet Explorer 10+ browser
Improved ToDo workflow when adding files to a ToDo
Improved ToDo workflow when adding views to a ToDo
New Features
Launch SketchUp from Connect
IE 10+ Support
Show "Create ToDo" option in "Add files to ToDo"
Add a view to an existing ToDo
ToDo: Completion progress field in user interface
Profile setup page updates: Job role
Create Activity event for project update
Team: Resend Activation Email to users
Update to Elastic Search 2.3
Add support for IfcXML
Improvement
Cleanup of inline styles in html templates
Activities: Previous entries should not get affected by latest changes
Start date should be always earlier than end date
API to provide Read-Only/No Access Folder information2 (for Revit API)
New ToDo creation displays old Labels after project rename
Angular UI - Previous entries should not get affected by latest changes
Team - Allowing the user to perform action for a user/group which is deleted in other browser - API
ClashItems (Attachments) added to ToDo are not listed in webapp, whereas in API response it shows attached successfully
Projects listing: Show proper error message if any of the POD will be down
Thumbnail is displayed in the right panel of the ToDo for the created clashItems
(CleanUp) Email Notification
ToDo list loading time is too high
Email - Improvement for comment notification
ToDo Filters do not work correctly
Email ids ending with country name need to be accepted
Team Import: Add a Column for error messages
ToDo list with ranged request loading time is too high
Bug
UI - Changing browser zoom makes the "Team" user interface fall apart
ES Mapping need to be updated based on the current db schema changes
When Large Size Folders are Deleted, Deletion is Delayed
ToDo is shows selected and details of uploaded file are seen in right panel.
Signup is successful even the user is already present in TID by signing up from other environment
ToDo from 3D not creating snapshot and ToDo not visible from 3D viewer
Public v2.0 API : Clashes - Issues list related to editClashsetRecipients
Auto save is not working
ToDo : ToDo attachment(no access file) is not seen for the user of the project
[Elastic Search] Group/Users Not Returned Even Though They are Indexed
Public v2.0 API : ViewGroups - Issues list 1 (Found during automation)
IFC file didn't get assimilated
[API] API Script works in Chrome but Not Internet Explorer
Folder permissions hangs on large number of files in folder
Files is getting downloaded and able to open file in 2D OR 3D viewer from deleted release/ToDo
Folder Deletion Causes LockTimeOut Exception
v2.0 View API : parameter validations missing
[UTIL] NA Util Scheduler Hanging Multiple Times (Post PROD Push)
Exceptions thrown as validations missing for release recipients in v2 api
v2 : GET folder versions API returns details of no_access folders
Incorrect alert context
Markups are not saved in views
[ASSIM] IFC File Fails Assim
[PERMISSIONS] Folder has Everyone but A Particular Group Cannot Access
Revit file is blank in viewer
Clash - Option "Ignore clashes within the same type" is buggy
[USER] User Invited to AP, EU Does not Show in Project When User Signs Up Manually After Invite
ToDo/ClashItems:Adding same clashItems in multiple ToDos is not proper
Angular UI : Internal Server Error with No error codes in response crashes UI
File deleted event shows as RESTORE IN PROGRESS after the file is restored
Even though group is deleted user can see activity filter enabled for the deleted group
Views : View is seen in the shared with me section even though it is not shared with admin
[DWG] 3D DWG Files Assimilate But Load Blank
Password : Not able to reset password with old password in Profile page which is possible through TID
[PERMISSIONS] Inviting User and Setting Group Fails User to Adhere to Groups Permission
[USER INVITE] Second Invite Sent to Unactivated User is not Activation E-mail
[Angular UI] Sync Activity : "Synced the project" text is missing in all the sync activities
[API] /folders/by_path Returns Not Found For Deleted-Recreated Folders
Public v2.0 API: ToDos - ListAllAttachments : Able to list attachments for deleted ToDo
Markups getting deleted from Views/ToDos
Project access - Email content shows company name of the project for any random user
If-Match header validation needed for file/folder APIs that modify resources
[Angular UI]-Project Details-Wrong Error message when Admin tries to leave the project having only one user in project
Optimize handling of long running jobs
IllegalArgumentException on views created from TCD
Public API V2: Folder checkout / check in response
[Angular UI]-3D Viewer:Alignment settings is broken when the alignment action is performed for the first time by the invited user
BCF import changes the name of embedded view in ToDo
When one POD is down and Filter is enabled for that POD, not able to navigate to other POD projects as well
Upload error - org.hibernate.exception.LockAcquisitionException
Public v2.0 APIs : Issues found in Files component API Automation
File:File B gets deleted successfully and selection remains the same from left panel and File Deleted activity is not visible in activity page
[Permissions] Re-Named Folder Does Not Appear to Non-Activated User
Public v2.0 API : ToDos - Issues in Add Attachments API with type VIEW
Comments API - User can create comments on unassigned release
Comments API - Message and errorcode inconsistent when trying to create comments on deleted objects
Clash is stuck in processing state for renamed skp file (queue_id=20)
[PERMISSIONS] Removing Permissions Exposes SQL Batch LockTimeOut Exception
[PERMISSIONS] User with Full Access to a Folder via a Group does not see Child Folders
[PERMISSIONS] Multiple Permission Issues Affecting GT-Services Projects
[Angular UI]-Search: Project search does not list all projects and also slow in loading it.
V2 API : Get Folder versions thorwing "PERMISSION DENIED" error for the user invited after revising folder
apidoc.html - Font family not loading
IE issue : Background color which is set in Viewer settings is not reflected in viewer
Comments APIV2 - User removed from project or not part of project can create comments on ToDo
Email:Instant Email text for comment added/deleted/edited for view is not consistent
Comments API - User editing comments on ToDo (NO_ACCESS, USER_NOT_IN_PROJECT and USER_REMOVED_FROM_PROJECT) - Response message is not consistent
V2 API : When invalid view id is passed for View or View group related APIs, getting the error message as "Please provide a valid value for snapshotId". snapshotId should be replaced with viewId
Public v2.0 API : Clashes - Issues list related to Create/Edit/Get/Delete Clashsets
V2: It is possible to create view on deleted project
List Comments API V2 - Response message is incorrect
List Comments API V2 - User who has No Access, Not In Project or Removed From Project can get list of Comments for ToDo object type
Folders - User/Admin should not be able create folders with more than 255 characters
[Angular]-Team:Newly created Group Name is not shown Remove Users from Group.
2DViewer/3DViewer : LeftPanel :ToDo status list order is interchanged for Done and Waiting Status
3D Viewer-No Error message seen for corrupted 3D file
Release :Back end error code is observe while creating release with null due date
Invite New User : Inviting new user should take the user to the TID Login Page instead of TC Sign up page
Password Validation tooltip in TC Profile Page should match with TID
[CLASH] Fails CLASH_PREPROCESSOR
Clashset stuck at 0%
ToDo: User is able to export multiple ToDos to BCF
When a user tries to access a deleted project link, Request access link should not be displayed
Releases do not appear to users added after it was sent
Exceeding folder path length due to many levels causes exception
Status for 2D Files not Correct When Processing has Failed
[Angular UI]-3D Viewer: Unit settings miles(mi) is not reflected in Quantity take off reports,Room schedule Report and Create Clash Dialog.
[Angular UI]-3D Viewer: Custom Reports are downloaded with different message in background.
Eventhough user is not renaming the folder, new ID is getting generated for the same folder name.
Compliance Api : Refresh issue
the file api /status for dwg is returning UNSUPPORTED_FILETYPE
Angulr Ui-File:File B gets deleted successfully and selection remains the same from left panel and File Deleted activity is not visible in activity page
After download of BCFzip, the ToDo page right panel gets messed up
Public API V2: Release,ToDo is getting created even through passing '00' as date n month
File is not getting uploaded to Webapp project when it is synced(Uploaded) from SYNC tool.
[Angular UI]-Add Files to Release: Follow up ticket of GTEAM-2910
Activity: ToDo description of Create ToDo activity getting changed
Follow up of 8685: RVT file synced up should not enter assim queue.
3D - ToDo right panel goes blank when user updates the ToDo.
ToDo: Nothing happens on clicking View attached to a ToDo from ToDo right panel
Clicking on a No access view attached to a ToDo opens it in 3D Viewer
<ToDo> When user is changing the ToDo priority or status in 3D viewer, the selection gets lost from right panel
Staging: DWG and DXF thumbail gen failure
ToDo - Clicking Thumbnail does nothing
Clashsets - Incorrect message appears when there are ZERO clashes.
Profile : Update is not happening correctly in profile page
ToDo : Sorting is not working properly for createdBy Column
Activity : ToDo created by clash items activity is creating multiple time for each clash item
Incorrect company name in user profile
Status of the checked out file is not changing after restore
Model tree missing in QA EU pod
Opening mashup of assimilated + processing file should throw alert
Project details : Exceptions are seen in project details page
EU POD - 0 is the number of clashes found
Email Notification:User email address is not full informative
'Please refresh your page' is not needed in alert message for permission denied case
Projects - Project Description is NOT getting displayed in List view.
skp files are not processed correctly
IE : Drag and drop is not working in IE browsers
Search API fails when searching in a set of projects
Email Notification :Cliking on Thumbnail for ToDo in notification email is not refer to exact object
To Do – Import from EXCEL not working as expected
Public v2.0 API : ViewGroups - Update API throwing NPE when name parameter is not passed
Search API throws Exceptions with certain strings
Clashset details are not getting in the right panel
ToDo : Not able to add files to ToDo
Public API V2: New Project is getting created after passing start and end date as 00 for month n date
Console errors are seen in different places of the application
Patch Project calls fail
Invite button on team page is not displaying
User trying to delete project error message is getting displayed "java.lang.NullPointerException"
Project : In add user API, the error code has been changed to generic
Release :"Not able to send release for New Project for both POD "
ToDo: Unable to remove clash items attached to ToDo
Release:Add Files to Release window shows selected files two times
3d Files:are not assimilating in Staging
Difference in assimilation of DWG,DXF between the pods
DXF and DWG fails assim on folder with space [AP]
Reset functionality under Model Tree is broken
Cannot download files in pdf format
TCZIP and IFCXML are not processing
Issues in If-Match header validation for file/folder APIs
Updating the revision of DWG file throws 500 error in 2d viewer
API - CORS Failure in Connect API v2 Including Range header on bimdata/objects-query POST
Views - Not able to assign view to a User, Save button not working.
ToDo API - Updating a ToDo deletes any current assignees and reverts the priority to NORMAL
Profile Page: Not able to edit the profile details, when trying to edit from non Master POD project page
ToDo : Completion Value is not getting saved while clicking outside the field
IE10 - Delete ToDo dialog is hidden behind the viewer
Deleted file cannot be restored from Activity page
