Trimble Connect for Browser 2.42 & 2.43 | Release Notes | October 20, 2016
12-20-2016 17:56
New Features
  • Document markup tools (Beta) for PDF, Drawings, Office documents with integrated ToDo workflow
  • Create .skp models using our new native SketchUp modeler without leaving your browser
  • Civil and construction engineering applications in the Trimble Connect application store
  • Improved ToDo workflow when adding clashes to a ToDo
  • Terms of service is updated. Please review the updated version here.
  • New logo for Trimble Connect
Improvement
  • Large folder/file deletion performance improvement
  • Activity page performance improvements
  • Folder Permissions change performance optimization
  • Release files show file versions
  • Size Column Does Line Break When Screen Size is Reduced
  • Date component should accept valid date input directly
  • Include folder count in all public v2.0 project APIs
  • Settings page UX updates
Bug
  • Measurement unit is not changing according to the option selected in 3D settings. Always it is shown in "mm" unit
  • Sorting with Range header is not working properly
  • Sync settings : User of the project can change the sync settings
  • Differences in model appearance and thumbnail
  • Misleading error on signup page for user invited to project - EU & AP
  • Error message is NOT getting displayed when user tries to remove files from a sent release
  • More button is missing from clash data page
  • User able to view get Folder items response for No Access folder
  • User can download "no access" files from clash
  • Email : Invited user name is seen along with domain in the instant email
  • User not able to create view in specific workflow
  • Sequential File Phase Not Updated When Assimilation is Complete
  • Queued Batch Contains Job with no queue_job_id
  • Rotational Angle Does not Persist
  • AutoUpdate Dialog Box Causes Confusion of Error Message
  • Non-Seq. Batch Does Not Move to Dereferencing
  • Angular UI : Clashset deselection in the left panel of 3D viewer is inconsistent.
  • Inconsistent search results are returned
  • Selected folder from central panel is not visible,highlighted in left panel
  • User with no access or has been removed can open files from todos, views, etc....
  • Alignment is NOT proper for Save and Cancel button in right panel
  • TC has missing properties in Revit translation
  • A line appeared in Type / Groups / Users section in left panel, though the check box is hidden
  • Add comment button halted in Working Status.
  • Even through clicking on thumbnail of file is not going to open in viewer like list view
  • Project loading icon behavior incorrect
  • UI Display does not account For Daylight Savings Time
  • Wrong markupId returned during PATCH
  • Models in Clash Report does not have the renamed model name
  • Assimilation issue - IFC Files works fine in TC desktop but not in TC web
  • As admin user getting error setting permissions
  • Latest update is not applied to the view and section plane parameter is null in request call
  • Invalid Value is retained even after cancelling the Edit group name.
  • Sign in page gets cutoff on mobile safari (iOS)
  • Selecting multiple files using shift button does not work
  • Thumbnail missing when file processing completes
  • Files that fail at times succeed at others
  • Download file error
  • Renaming/Moving a file causes 2d assim fail and throws Internal Server Error
  • Email Notification:For some activities Project name is not consistent in mails before project rename
  • BCF without view does not get imported
  • 2D file processing delays in US
  • SKP file fails to assimilate in a Bench Mark Test
  • 3D view is blank on load
  • Email Notification: Comment added description is getting replaced by comment edited description
  • Profile : "The page you were looking for doesn't exist" message is seen on clicking documentation link
  • Clashset - Getting error "No row with the given identifier exists: [com.gehrytech.gteam.bim.model.ClashCheck#5849]" when user tries to enter Tolerance with very large number.
  • Getting error message in 3d viewer " Not a json object" when opening a 3D Model
  • User permission with Full Access and Read Only access are not working as expected
  • IFC colors are not correct
  • 3D Viewer-Markups cannot be deleted when viewer is in full screen.
  • Type of clash/clearance item is wrong in exported csv
  • Projects - Last visited by column is getting updated for all projects when user just logs off and logs In again
  • When user tries to edit company with special characters, Error message is not getting displayed
  • IE11 - BCF - Export download email link doesn't work
  • Safari - BCF - Export download email link doesn't work
  • Move file creates a new revision assim job
  • Inviting user gives Error SEARCH_QUERY_FAILED" and in console getting 409 conflict with {"message":"no such index for query ","errorcode":"SEARCH_QUERY_FAILED"}
  • Import loader popup cause server to stop processing for IFC file
  • Objectsync: Fetch Objects returns API caller's DTO as modifiedBy user DTO
  • Groups with 2 characters are shown in Autocompete but Save and Cancel buttons are not seen and the text is displayed in Red
  • When user is trying to delete todo no error message is getting displayed in 2d viewer
  • Ifc files cannot be seen in different browsers
  • Project Photo several pixels wider than Project Panel
  • Export files list to Excel : Files location column is not content Folder path from root folder
  • 3D - In Alignments scaling section the "From" and "To" dropbox moves along with the mouse scroll
  • [Activity Page] Activity Page Calls All Content-Range at Initial Load
  • New Project - Info popup messed up for project server location
  • [ASSIM] IFC File has wrong geometry
  • Newly created Object is not indexed
  • 3d viewer - RVT - Object properties doesn't show
  • Export /Import ToDo to excel:Email Link is not getting expired after 72 hours
  • ES is not working consistently
  • SKP file fails to process correctly
  • Activity: Inconsistent activity for todo created by selecting files/clashitems/views
  • PDF file failed to process
  • Console error is seen while opening the land xml file
  • Unable to invite user in a biz project in EU
  • [Firefox] Downloaded filename change from space char to %20
  • [Releases] Oldest file revision selected
  • PO - SM portal does not have add and remove features for seats
  • Eventhough view and ToDo is shared with the user, Permissions error is getting displayed.
  • Clashsets - Selecting a clashset gives "You do not have permission for this action" error
  • PDF failed processing
  • Profile setup page refresh issues
  • [Activity Page] Activity Page Does Not Load for Project
  • [Project Page] Project Page Takes 10 Seconds to Load in NA
  • Getting "Not a JSON Object" error when we try to open a view. This is inconsistent behaviour.
  • API - Showing time in response for Project Creation, Releases and ToDo.
  • Public APIs invalid session error code should be 401 - Unauthorized
  • Getting "You do not have permission for this action" error, when the user clicks on right panel for Todos created by other users.
  • Exception are seen while assigning permission in firefox browser
  • Public API V2: Able to set an image for the deleted project
  • User not allowed to rename files without extension
  • Changes needed in Error message in public V2.0 APIs
  • [Regression] - Error in processing PDF files
  • Multi part file upload fixes
  • Line break missing in multi-line activities
  • Clash name disappears when the clash is shared with someone
  • Thumbnail is displayed in the right panel of the todo for the created clash Items enhancement of GTEAM-8531
  • 3dm File From Rhino Missing/Losing Detail
  • Invite User :While inviting Multiple users observe "Internal error "
  • Projects - 'n' projects are getting created while pressing enter key 'n' times
  • Team : 'There are no users' message is seen for few seconds before listing the default users list
  • No permission to view clashsets
  • Files are not correctly assimilated
  • 3d viewer : New markups which are not saved should be deleted when we select any todo in left panel
  • Multiple objects are created for multiple clicks on submit button or pressing entering key
  • Autocomplete : Group/User Search happens with first two characters only
  • Clashset/view :while deleting Todo attachments submit is not working for delete dialog box
  • Predefined name (_other) is getting displayed when user is trying to create new folder and project instead of blank field
  • Ecom: New user profile cannot be fulfilled correctly for non public domain.
  • Fix needs for X-TrimbleConnect-Client header should accept different values
  • Activity : Blank Delete Activity is generated while trying to delete a file which is associated with todos/releases
  • Release : Downloading the file attached to a release always downloads the first version even though updated version is attached
  • Checkin a non-checkout empty folder throws "Are you sure you want to override checkout?" pop-up
  • Getting NPE when the user who is not associated with company calling /2.0/users/me API
  • Release : Release is getting deleted even though the deletion is cancelled
  • Issues observed in search component
  • Newly assimilated 3D file is not opening in 3D viewers except skp files
  • Clash : Clash calculation is taking more than half an hour to complete
  • V2 auth API throwing Exception: Failed to get Plan info for User
  • Assimilation inconsistencies on sync upload
  • V2 API : Create project API failing ,when the licenseId is not provided in the request, though the user has only one license
  • Search with Date Filter Today feature does not populate with current date
  • Clash - Number of Clashes increased because of element type name changes
  • Issues observed in search component (Issue 02)
  • BCF import should create explicit snapshot
  • Unauthorized_license_Project_access error code is displayed in the UI
  • Team export to excel column names incorrect
  • Import from Excel : Invite is not sent to the users who are invited using Import from Excel option
  • 2D viewer : console error is seen while clicking the thumbnail of the created todo activity after unlinking the file and todo
  • Project Specific - File Has Already Been Deleted
  • Refresh issue on project listing page
  • Folder Permissions : Inconsistencies in permissions between sub folders created before and after applying parent folder permissions
  • Team Page Performance is Slow
  • Views Right panel Activity - Spinner is seen even though there are no further activities
  • API key generation issue
  • Signup : Signup with already activated account does not throw account already exists error
  • Folder:while searching for folder having long name search is broken
  • Pending user delay in showing on team page.
  • Lazy loader response is blank
  • Using a Password with a ; (semi-colon) Causes Authentication Error when Logging In
  • Performance: Switching between All tabs takes long time to show the data.
  • File failed processing
  • Clash - result.bsq file is 1KB , clashes found are 121051
  • Exception error on the project while trying to open file
  • Search - Text containing hyphen(-) can't be searched
  • Activity : Folder/ File move activity is inconsistent
  • ToDo: Observe "java.lang.NullPointerException" while removing attachment for todo and deleting view
  • Navigation to search result item from different pod throws NOT FOUND errors
  • ToDo - When user deletes the attachment the ToDo itself is getting deleted from 2D
  • Project details page: as a single admin while leaving project observe error code "LAST_ADMIN_LEAVING_WARNING"
  • Files:Files selection is not remaining same after adding files to todo on data page
  • Settings - Nothing shows under 3d setting form fields
  • ToDo type not return result for Chinese char
  • Folder:Parent folder permission is getting applied for sub folder as well even through selecting option as apply to folder only
  • BCF Export Does Not Work With Implicit Mashup
  • Performance of Export ToDo is Slow to be Processed
  • BCF Compatibility with BIMcollab - BCF Manager
  • Import Bcf from Tekla to TC + Bcf support with multiple view
  • Todo Selection issue: Todo attachment and thumbnail is not visible if checkbox clicked
  • Views with camera looking down orthogonally to a surface cannot be viewed in the web
  • Clashset : Newly created clashset/view are not getting listed in clashset/view Created by me
  • Clashsets and Views are not getting listed in Left panel
  • Restoring 0.2 GB file fails when usedStorage is at 9.9 GB in free project
