View Entry
Back to Library
Trimble Connect for Browser 2.44 & 2.45 | Release Notes | Jan 18 2017
Recommend
02-24-2017 00:00
Karthik Rajagopal
Trimble Connect Web
New Features
Add Tags for File, Folder and ToDo for logical classification or grouping
ToDo: New fields (Title, Type, Tags) for BCF 2.0 format support in user interface, API and import/export features
Activity: See details of files from various activities like upload, download etc in right panel
16 languages
are now supported in the user interface
2D Views
Launch
my.sketchup
editor from Connect
Public APIs
Tags APIs
Get project settings
Set project settings
ToDo Implicit attachments
Version filter for ToDo listing
Version filter for Views listing
Commerce API: Request access email to Account Admin
Improvements
Rotate and save orientation for 2D files
Profile setup page updates: Job role - User Profile page
Download file with markup/annotations except cloud markup
BCF Import: Handling missing filename in BCF file
Notification Email Update for Trimble entity name and logo
Add 2d views to new/existing todo in 2d viewer page
Warn users when exiting without saving markups
Release : Clicking received release from search results is not taking to received section
Progress indicator for BCF files
Add 2D processing progress
Performance for BIM Objects API is Extremely Slow
Clashsets: 500 internal server error is seen while opening a clashset which is in progress
Object ids for skp, dgn, or stp files are not in .f3d file
Failed to get Plan info error on auth/token
Force cache busting on all updates
Activity : User can see comment related activities of no access objects
Project/Invite User: Taking ~9 secs to open NEWPROJECT/Invite User dialog in both PODs
Option to overwrite or create copy during move of file with same name
Allow archiving of QueueJob table
Bug Fixes
Activity Page - Spinner keeps on moving for project never shows activities
3D : Disabling Flash in IE should show 'insufficient graphics..' message.
Error tool in Textbox doesn't disappear when user scroll the mouse.
GetViews list private API is taking longer
Search : Sorting is not working for Type Column
Hide button is not getting displayed as Greyed out when user hides the models
[ASSIM] Crashed/OOM Pop-ups Stall Worker
Clashsets : Sorting is not happening correctly for #clashes and createdBy columns
Thumbnail fails for the uploaded file which is renamed before assimilation gets completed
Elements missing in FBX file
Profile Page : When password field texts are removed, "This value is required" error message is thrown
Views : OR operation is seen instead of AND in data->views
Model tree does not show hidden state of objects
<invite user> New user is getting redirected to an incorrect URL
All TC Components should validate the name according to OS unsupported rules
Performance problem opening mashups in 3D
Views created out of (specific) DGN file in TCD are shown blank in web
Profile - Form field should get highlighted if customer is entering wrong information
Issues in restore deleted files / folders notification
Autosave does not happen for few places in the application
IFC - alignment issue
Email - Full file name in notification email
3D Viewer:Opening any 3D files shows 404 Error in console
Error Validation is missing for Recipients in Create Release window
View:For less activity spinner keeps on loading and observe error in console
Firefox : Field becomes editable but the cursor is not seen
Re-indexing happens continuously on same object due to round up in milliseconds on modified date
View filters get cleared if the view contains filters that backend does not understand.
3Dviewer : Console error while opening the 3D file in Non Master PODs.
Not able to upload Multiple files getting error "Project has been created. Failed to upload image, please try uploading again in details"
TID Sign up Page: Chinese First/Last name is getting changed after signup
Search: Bad error message on Invalid character in search query
API endpoint /{fileId}/content does not work for moved/renamed 3d files.
Text Input Does Not Follow Line Break
Updating a Todo Performs Unwanted Change to Priority Field
[Activity Page] Activity Page Calls All Content-Range at Initial Load
[Activity Page] Activity Page Does Not Load for Project
[Export to BCF] Performance of Export ToDo is Slow to be Processed
Sync tool should upload zip file
[3D Viewer] Location views of LandXML files
[BCF Export] BCF Compatibility with BIMcollab - BCF Manager
[BCF Export] Import Bcf from Tekla to TC + Bcf support with multiple view
While updating stale version of a object, getting the error code "STALE_VIEW" in UI instead of showing the error message
Search API - query fetches Todo with status and priority as "null"
Todo : In right panel, focus goes to top after saving details
User is able to see Edit and delete options for comments
Project : 'Project not found' page is seen when project link is accessed from another pod
[3D Viewer] Models Aligned in TCD Are Not Aligned in TCW
IE10+ - Issues that needs to be fixed from bug bash sheet as part of 2.42
Search : Filters lost on clicking 'search other projects' link from Non-Master POD
URL in BIM object property values are not showing up nor clickeable in 3D viewer properties panel
Consistent keygen errors found during API automation runs on INT EU POD
[IE browser, 3DViewer] Model is getting temporarily disappeared while using Orbit and Pan camera options
Issue with Mozilla Firefox Inconsistent behavior observe while Creating a Group
Restrict Compliance incompatible characters on signup
Need for an Access-Control-Expose-Headers header value in the response that includes the necessary Content-Range header
LockTimeoutException
Clashitems attached to a ToDo with underlying files having no access permission should not open in 3D viewer
Activity page has values missing and shows {{act.createdOn | tcDateTZ}}
Angular : Console errors (Cannot read property 'firstChild' of undefined) are seen while selecting views/clashes/Todos,Releases
IE10+ - Issues that needs to be fixed from bug bash sheet as part of 2.44
Add Files to ToDo : Updated file version is not getting reflected in attachment when the todo is created in the Add Files to ToDo dialog
Storage maxed out","errorcode":"UNAUTHORIZED_LICENSE" for PO Business User
Release : Not able to attach updated version of the file to a release for which already old revision of the file is attached
Clicking .tcmap is not opening up the map viewer
Project : As a single admin, if I try to leave the project, leave confirmation dialog stays as working until we click cancel
GDB file fails to assimilate if folder name is gdb.gdb
TC Bug Report on Alignment rotation calcs
Huge count of files in 'PROCESSING' status in email_log
Folder restore for project GT EU-BR INTERNAL [Project Specific]
Model alignment rotation angles displayed incorrectly
Team page is not loading while clicking on the Team page after viewing the user details
Profile Page : Profile photo does not accept .tif file
Untranslated keys seen on production
Team - Resend activation link messed up in Dutch language preference
User is not allowed to delete the todo created by import BCF file , though the same user imported the file
[Indexer] User Group for EU Not Returning All Users For AutoComplete
Translation of text to Dutch language is incorrect
[ASSIM] Moved RVT File Causes New Assim_Job Record Showing -2204
Sometimes cannot create views with element type filter
View containing arrow markups cannot be created correctly.
The color is ignored for the redlines markup
View and ToDo workflows are broken in QA
Activity : Admin file activities are not displayed to user
File : Move operation is failing for renamed file
Download fails & Checkout file returns empty response, after a file is renamed/moved
Search API not returning correct results - Indexing issue in QA EU POD
Search API throws exception
Public V2.0 APIs : Handling deleted Folders/Files under no access folders
[API] New Header Required for Download
Team - Invited users not showing on team page
[RESTORE] Data Restore Stuck In Progress
Console errors while navigating to any page (Activity, todo, team, view,etc) and scrolling in alignment accordion
Activity page fails to load due to IllegalArgumentException on QA
lastupdate date should get updated in storage object indexing for View and Clash record
{"message":"Failed to create project","errorcode":"INTERNAL_ERROR"} on QA
Error processing uploaded file - File greater than 100 MB fails interactive upload
[3D Viewer] Model Disappears While Rotating Model
Geo Files are throwing console errors for getViewStatus API and importing the same to maps shows error
Notification Emails are not sent for todo assignment and BCF export
If assim server is idle, uploaded dwg file will failed assim.
None landxml file AssimilationJob should have status = -3603
Issue in create release dialog
Project List Not Loading/Projects Not Loading
my.sketchup - Checked out files are opening in viewer instead of editor
While creating todo with implicit/explicit view, file is also added as one of the attachment
Instant Email is not triggered for "Add Files to Release" action
2d views : File name is seen instead of view name when todo is created with implicit view
Delete view is not working
2d views : null pointer exception seen when opening a todo containing explicit view
Regression Failures in Public API Automation Suite
HUGE count of daily digest email request came to email_log table
Team : observing 'Remove users from group' window while trying to remove user from group which is not associated with any group
