View Entry
Back to Library
Trimble Connect for Browser 2.46 | Release Notes | February 6, 2017
Recommend
02-24-2017 00:43
Karthik Rajagopal
Trimble Connect Web
New Features
Share data with other project users
BCF 2.0 Import: Handing attached documents into Todo
User can be part of multiple companies
Standardize map backgrounds to zoom level 20
Ability to view maps form data that has no position
Filter by user in Maps workspace for collected files
View multiple map data types in the same Maps viewer
Improvements
3D: Warn users when exiting without saving markups
Multiple view support for BCF
Handle move and rename cases with partial selective sync
Views and Clashsets listing in Data accordian take time to load
Search: Add project name to all indexed objects
Api changes for 2dviews attachment type for in getTodoAttachments api.
Modify the files array to String for the inputType and outputType in 2dviews api
Bug Fixes
Firefox & IE : Entire data in the page is seen selected while resizing the column
BCF : After exporting todo from one project in TC to another project, comment in the exported project is not showing up
IE10+ - Issues that needs to be fixed from bug bash sheet as part of 2.43
Views: Mismatch between values in right panel & middle panel while switching between accordions in data page
Release : File selection is not retained after creating a new release with the selected files
Angular - Drops downs are not aligning to the space available
User needs to click outside to see added markup
No alert for uploading files with more than 5GB
Upgrade Account - link error on Safari browser
[2D Viewer] PDF file doesn't open while trying to reopen it
Elastic Search fails for files often.
Putbatch should not create assimilation job if files priority is NA.
3D Viewer: IE:INVALID_OPERATION Error is seen in console when 3D files are opened
Profile Page: Auto Save option for the drop down Job title is not working when clicked outside of the field.
Add Files/Views to ToDo : Cannot click on Submit if the cursor is kept in DueDate field not provided any value
Activity : Null pointer exception is seen while filtering with groups
Error processing SKP files
[Folder Download] Sub-folders not present in zipped file
Translations needed for Entity Types in 3D Viewer
Clicking on Clash item attachment in a todo should open the particular clash item in 3dviewer
2D Viewer : Getting Download Failed error message while upload a checked out file in 2d viewer
Error is seen when inviting multiple users in both NA & EU PODs
2D Viewer : 2 alert messages are seen while deleting a file from 2d viewer
Same email id is seen in the excel sheet for all the invalid id.
2d viewer : permission denied message is seen when admin deletes user created view
Not allowed to access or create map workspaces - Thrown with No Permission message
Skp files uploaded are in Queue when uploaded with my.sketchup header
[Data] [Download] Manual download doesn't download all the files from the folder
Import in workspaces fails
IE10- Cant able to create view/todo from 3d viewer
IE10 - Nothing happens on clicking reset button
User not able to access shared view
IE 10: Model is not opened in embedded viewer
Selecting an element fails view/todo creation
2d views : permission denied message is seen for admin while editing an implicit todo created by user
Error is seen when selecting the release files under no access status.
Error is seen when listing the users in team page for few projects. NPE observed for the API call
Console error "RangeError:Maximum call stack size exceeded" is seen after deleting a Todo from 3D viewer
