View Entry
Back to Library
Trimble Connect for Browser 2.48 | Release Notes | March 9, 2017
Recommend
04-26-2017 14:10
Karthik Rajagopal
Story
ToDo: Bulk edit functionality
Company Administration: Company Profile
Public API:
Company users list
Create and show thumbnails for Maps workspaces
Improvements
Improved new map workspace workflow
Consistent Zoom Behavior in Maps
Styling for RTConfigurations
Add keyboard shortcuts for additive selection
Instant Emails are not triggered for View deleted activity
Instant Emails are not triggered for ToDo Edited activity
Changing tags association should change the object timestamp similar to attachments. This should trigger the change in the object type HT.
Creating view with renamed/updated model not working
Create ToDo Edit activity for missing fields
Search: ToDo listing visible only to creator, admin and assignee
GEO API : Change the extension of map files from .tcmap to .tmap
Bug
Views : Clicking on view thumbnail in the right panel loads the view in 3d viewer only once
IFC file assimilation failed
Sync.Net: Email notification shows folder counts as files count and folder activities are missing
Activity : Edited release name is seen in the activities which were performed before renamed activity
PDF: opening second revision of a file throws error
Files API : Hidden input param should be renamed as "hidden" and API should return 400 for invalid and blank hidden values
Public API Doc : Fix all standardization issues
Styling issues that need to be fixed when translation is applied
DWG fails to generate pdf and image file for some file
Performance : CSS not loaded from cache though content was not modified on server
Views associated to ToDo are not getting deleted in 2D viewer
[Sync.net] Allow user to add .DS_Store in the excluded file types
Activity : Deleted view/clashset activity is not seen for user
2D views: 'Object not found' is seen while switching between revisions with comments tab opened
Sorting clashsets by type property api throws duplicate items
Add Files to ToDo: This value is required message is displayed unnecessarily
Add Views to ToDo: Views selection is not retained after adding the views to existing ToDo
Embeddable map viewer - Writing library script - Enhancement
java.lang.NullPointerException when creating clashset without models
Yes/No fields that haven't been answered show a value of 'None' instead of being null
Unit label isn't shown beside value for Estimated Accuracy autofields
If you are scrolled down in the Workspace list then search, no results are shown
Scroll can get messed up when deselecting fields
parentId is missed on file versions API when parent is renamed
Site goes down even if one POD is down
MAPS - When loading a large workspace - performance issues
MAPS - Loading the template library performance
MAPS - error while restoring layer
Double folder/file entries seen in data page
Styling - Template editor - Required() and Lock icon overrides condition/target icon
Selecting Unassigned user doesn't display feature that is modified by some other
