Trimble Connect for Browser 2.49 | Release Notes | March 23, 2017
03-23-2017 14:42
Story
  • Company Administration: Manage company profile and manage users
  • BCF 2.0 Import: Attached documents are supported as attachments in ToDo
  • Performance optimization of APIs
Improvements
  • Ability to Filter with Removed/Deleted Users in Activity page
  • Detailed viewer: Display Sketchup file in processing
  • API: Comments support for 2dviews
  • Tool-tips for keyboard selection
  • Remove all PNG format icons from map viewer
  • Email notification cleanup
  • Filtering by group (without any users in it) does not list objects assigned to the group directly
  • Performance improvement: Folder-File activity takes long time to load
  • Add the ToDo Title field as searchable
  • Tag Search support for ToDo
  • API call to get the list of ToDo type available for the project
Bug fixes
  • Section Plane Not Aligning With Model
  • Folder :Search result does not take user to folder itself
  • Toggle section plane enlarge after click ToDo Details
  • Team: Invite an already existing user in project, creates a new activity
  • Activity - Deletion activity is not seen for created user
  • Change the DB status for skip assim files status to ON_HOLD
  • 3D viewer: Reports generation throws error
  • Team Page: Company name not displayed for some users
  • Clicking cancel button closes the create dialog but its api call is successful
  • Projects: Clicking on tile/list view button second time, projects are not getting displayed.
  • User received > 1 Project Daily digest email
  • Fetch objects API not returning all the views
  • ClashSet deletion is not correct in ObjectSyncAPI
  • Cancelled Job status for SKP file is not reflected on UI
  • If file download failed, no queue_job is created for the corresponding assimilationJob
  • Due date of a ToDo moving backwards 1 day when saving
  • Activity : View related activities (renamed view,updated view,updated description) are seen to user for whom access is not available
  • lastVisitedOn cannot be updated by user in "USER" role
  • 2d viewer : Download failed error message is seen and file is not opened
  • Folders Restored Do Not Retain Permissions
  • When I open a template to edit it, the first field is always expanded
  • MAP - Publishing a template in large workspace - performance issues
  • Styling- All panels (Data/filter/ToDo) in map being dependent doesn't look and feel good
  • Team page not working and unable to invite users
  • MAPS Template editor loading
  • Clean up task for Double folder/file entries seen in data page [project specific]
  • 3D DWG file error out when upload to non-English characters folder name
  • Opening Map workspace from TC redirects to wrong URL
  • Daily digest emails are received twice for same project
  • Search result shows the deleted files
  • User permissions should handle in ES for Group and Project
  • 2Dview object sync and thumbnail issues
