View Entry
Back to Library
Trimble Connect for Browser 2.50 | Release Notes | April 27, 2017
Recommend
04-26-2017 16:19
Karthik Rajagopal
Story
Add attachments or hyperlink to a location on the web to any BIM Object in a model.
Search results show location breadcrumbs for easier navigation
ToDo: Download attachment option
ToDo listing visibility settings: set ToDo visible only to creator, admin and assignee
Responsiveness of Template Editor
Improvements
Search keeps on loading when the search text is more than 1024 characters
Remove map workspaces from hamburger menu
Make a list box for ToDo type selection based on the given list of
ToDo
type in the project
Instant Emails should be triggered for View deleted activity
RTC - Change "Click to load NTRIP Source" as a button and text input after clicking on it.
MAPS - Utilize title field in
ToDos
for TerraFlex and Map Viewer
GEO API : Modify maps API to POST activities (Template)
GEO API : POST generated Workspace Thumbnail to API
GEO API : Modify maps API to POST activities (Workspace)
Bug Fixes
Activity : Right panel activity shows only Latest 12 activities. Previous activities are missed
Profile - Form field should get highlighted if customer is entering wrong information
PDFTron - Getting warning and error messages in console while loading 2d file in pdftron
Project : 'Project not found' page is seen when project link is accessed from another pod
Alignment : Markups are not moving along with model while aligning
Private API : /app/users/me is taking longer time in Staging AP POD
Activity : Individual activities are seen for each folder instead of single activity when uploaded through sync
V2 API in Staging AP : V2 API calls are slower in AP POD
Todo : Markups added for one file is seen for other attached files also
API doc missing for : Request access email to project admin
API doc for: Embedded Attachments
Default workspace is not created when user cancels the creation of initial workspace.
IE: Background color is missing for the feature count in Todo panel
Handling broken geometries
Thumbnails for anything
Use the latest published template, rather than just the latest template version for display in the map viewer
Images from the field are not rotated correctly
Dex fails to show Asia pod projects in TF mobile app
[ASSIM] Land XML Files Shows in TCD but not TCW
Hidden Files : Hidden files are not visible when isHidden param is set to false
Console errors thrown while creating workspaces
"Cannot connect to server" error is thrown for users with large number of workspaces
Styling- Sucess message for layer to template conversion is not in user understandable format
Tags should not accept OS Unsupported characters as tag name
MAPS - Fileviewer empty
Export by 'All map workspace data" filter- file count in the downloaded zip is not matching with the layers(with features) count in workspace
Aggregation is not happening properly
Automatic refresh is not happening for many operation throughout the map
Thumbnail is generated based only on the collected feature and doesn't show the imported feature
Workpsace creation from TC is not working
Lock layer not working as expected from mobile app
2D Views : Views not shared are able to share and view by User
FE-Complete Testing for share data feature
Long list of upload files in active uploads doesn't display the entire list
3Dviewer/2DViewer : Not able to unselect View by clicking on the view on left panel
Non Master POD : Activity : Batch view is failing for delete clash action
RTC-Serial port - Scrollbar overlays the fields
It should not be possible to add a field with the same name as existing field
MAPS - text update to remove reference to task
Update API left panel contextually
Clustering is not happening while applying filter
Layers/Data panel needs to be visible by default in new workspaces
Exporting a mix of forms with and without geometry creates incorrectly formatted data
The status property is wrong in Object Sync API for 2D Views
Status is wrong in Object Sync & Embedded 2dviews are missed in ObjectSync
Some queries are taking too long
[Releases] Send release emails aren't received by the users
View continues to refresh when right panel ToDo properties are edited
