Trimble Connect for Browser 2.52 | Release Notes | May 30, 2017
05-26-2017 14:06
Story
  • Add/Remove tags on views for classifying views
Tags on Views
  • Search for files inside projects with the option to Download, Add to Release and  Add to ToDo
Search commands
  • ToDo: View and locate file attachments
ToDo Attachment Commands
  • Search on deleted objects
Improvements
  • ToDo: Export to excel  should be as per user preference time zone in application
  • BCFZIP files imported to include Assignee details
  • Delete and restore feature performance optimization
  • Views rendering only support for redlines free hand markup
  • Views: Ability to display multiple section planes
  • Missing properties for views
Bug Fixes
  • Pressing enter key doesn't move to the next line instead hits submit button
  • MySQLSyntaxErrorException when calling DAO with empty list
  • Not receiving mail notification for export
  • Information about number of views added to ToDo is not included in activity feed
  • Timestamp needs to be updated when a custom basemap is deleted
  • files/uploadAttachement api allow user to upload file more that free storage limit
  • All Workspaces un-assigned from user
  • ECom: Authentication via API with new user/incomplete profile information does not produce expected error
  • Job Title can't be allowed for edit when user select OTHER
  • Can’t select features on map after map refresh
  • API PATCH Method Not Working As Describe for Existing Permissions
  • User deleted read-only folders without permission
  • Backend changes to PATCH API for making Notify field optional
  • ToDo can’t be created after file attached in model is deleted
  • If view with section plane is selected, the section plane is not removed when we select other view in left panel.
05-31-2017 03:26
Hi Marko,
It looks like not all functions are published. We can't find the locate in explorer function...
05-31-2017 01:22
Hi Bryan,
The 2.52 is now released.
Best regards,
  Marko Myllymaa
05-31-2017 00:17
Hello Karthik,
Is the new webversion 2.52 of Trimble Connect released already?
Or did you pre-release only the notes?
