View Entry
Back to Library
Trimble Connect for Browser 2.53 | Release Notes | June 15 2017
Recommend
06-07-2017 09:33
Karthik Rajagopal
New Features
Create new project from an existing one as template for quick project setup, maintaining folder structure standards by work breakdown etc.
Onboarding experience for users on project data
Export project activity to excel. In excel you can analyze activity graphs by trade, company, activity type and much more...
Add multiple section planes (up to 8) with models in 3D viewer. Views can be more consistently shared across Trimble Connect Web, Desktop and Mobile.
Add permissions to multiple selected folders at once
Import to Map Workspace from Connect
Improvements
API - to search on deleted objects
Exception handling for resource maxout while clash checking
Populate model cause out-of memory exception for very large models
TCD compliance workflow: adding localization
Align object linking workflow to select tool
Project settings: Email notification for Views, ToDos and Clashsets
3d viewer - Align - Files are not correctly aligned as seen in desktop, mobile
Per page cursor value is needed in Delta API
Changes in the file thumbnail are not reflected in HT API
Object linking - Permission left panel
Share Data: Share dialog notify field should not be mandatory
Search: Migration of Old deleted objects
Clear filter button - API changes to fetch counts in other screens.
Show error message only when we first open view/clashset which has the deleted files
Bug Fixes
Add model placement (alignment) support to HT and Object Sync API
Clash creation stops at 1 percent
Release : Able to delete a released file, while deleting a folder containing the released file
Not able to create ToDo in 3D viewer
Search: Newly created objects are not indexed for Europe region projects
V2 Get List APIs : Response code and Range headers are wrong
Bounding Box Information is not being stored in DB for ifczip file
No meaningful error is thrown when trying to hit no access workspace
Shared workspace gets deleted once after hitting the URL
