Trimble Connect for Browser 2.54 | Release Notes | June 28 2017
06-16-2017 17:33
Enhancements
  • Option to restrict project invite feature to project administrators only for enhanced security
  • Team page user experience improvements
  • Subscribe to processing completion notification email on any file
Improvements
  • Adjust transparency on the read-only access folder
  • Performance improvement in processing and clash items
  • MAP - notify of app requirements when creating a ToDo
  • Views : Views are getting loaded in 3D viewer based on the alignment
  • Option to open DWG file directly in 3D viewer
  • Revisions in 3D viewer: allow users to toggle between revisions in 3D viewer
  • Search: UI should show filesize property for Files in the search results
  • Project settings: Email notification for Views, ToDos and Clashsets
  • Fetch POD Specific Thumbnail URL
  • Template editor: Validation messages: Validation rules needs to implemented.
  • Template editor: Validation messages: default validation messages (like maximum and minimum) needs to be implemented.
Bug Fixes
  • Displays Incorrect Date and time in excel after exporting the activity.
  • Getting rollback exception intermittently when we do multi folder permission
  • Views: Views are not getting updated after adding few line markups
  • cloud markup is not seen in  viewer when traversing between revisions and ToDo accordion
  • Breadcrumbs : Folder path is not refreshed when folder is moved
  • ToDo : permission denied message is returned when user try to update the assigned ToDo
  • 2D Error When DWG Files Being Mashed Up
  • File undelete functionality broken
  • Cannot delete file if it is attached to the deleted ToDo
  • Occasional UnexpectedRollbackException on creating views in parallel
  • Tag indexing need to update for search.
  • Constraint Violation Error seen in PROD
  • Fix Object Sync Slowness
  • Wrong creation timestamp in echo on undeleting folder/file
  • Wrong creator in echo on undeleting folder/file
  • [Data] User haven't received export email for files
  • Range requests for file content download are not supported
