Trimble Connect for Browser 2.55 & 2.56 | Release Notes | July 27 2017
07-11-2017 09:54
New Features
  • Root folder permissions: Project administrators can now restrict uploading files or creating new folders directly under the root folder to enforce the project folder structure
  • Search files commands: Project users can easily Share, Export to Excel, Add to ToDo, Add to Release etc. with files directly from search results.
  • Releases files commands: Project users can View files, Add to a Release, ToDo, Share, Export to Excel etc. with files directly from a release.
  • Comment attachments: Project users can attach documents from Trimble Connect, Upload attachment or add a URL to provide more information in the comment for better collaboration
    • Restore folder permissions: Option to retain original folder permissions or inherit current permissions from parent folder with restore
    • Team Invite: Easily add more users from your company directory
    • Object linking API (attaching documents and links to BIMObjects) See documentation
    • Select any 3D view in Revit for upload
    Improvements
    • Team Page - Improve Performance of List Users in Project
    • Email notification for 2DView assignee
    • Activity generation for 2Dviews
    • Performance with Loading IFC model which has 500K elements
    • GEO API : Form template service
    • Viewer API does not seem to expose any events like "onSelect" or "onDeselect"
    • Search: UI Show filesize property for Files in the search results
    • Make compliance check mandatory irrespective of the flag status of ecom_use
    • Ability to expand RTC column widths
    • Maps: Performance and stability
    • Maps: Layer  panel should show names of the workspaces it is linked to already
    • Thumbnail updates for Object Sync API : TCPS - 596
    • Complete data reIndexing takes long time
    • User prompts in Template Editor
    • Land XML can have same hierarchy like uploaded IFC files
    • Validations added for Company Admin while editing access and removing admin
    • Activities: add object version number when exporting activities to Excel
    • Ecom: Adding additional parameters for Ecom 3.0 in API response
    • Maps: Layer linking - improvements
    • Maps performance: load map with more users
    • Maps performance: switching between workspaces
     Bug Fixes
    • Assimilation failed for certain landxml file
    • Activity in right panel for ToDo takes too long
    • Revoke functionality broken for Shared data with View and Download
    • BUG: Error is seen after clicking on Sent release
    • [Manual Download] File download speed is slow
    • Maps: After creating base map view zooms to wrong one
    • RTC- internet- Datum field is not displayed if either username or password is left blank
    • The fields in the downloaded file is not matching the feature attributes as displayed in web
    • ToDo filters do not work for groups & assignees other than creators
    • API throws correct error but UI shows Internal error is seen, please contact support message
    • Republishing an update functionality is not working correctly
    • Renaming and clicking enter saves the workspace twice
    • Maps: Add ToDo form refers to New Task not ToDo
    • ToDo features gets appended to the old feature selection panel(on maps) instead of displaying a new RHS task feature pane
    • Maps: Two different versions of the same form appearing in TerraFlex
    • Maps: UI: text input fields are not working properly
    • Duplicate layers and Question mark Icon appears on uploading a multi geometry files
    • "Authorization denied" thrown while calling API's through Postman/Swagger
    • [Team] Importing users to project throws exceptions for non TID users
    • Incorrect error response (304) on file rename : TCPS-712
    • Inconsistent error response (400) on file move : TCPS-713
    • Maps: Closed tab is hidden behind the TIP message after closing all ToDos
    • Maps: Map Viewer shows a wring TIP alert for adding templates which is not supported
    • Maps: In RTC POSITIONING panel, check boxes behavior under Map workspaces column is not correct
    • Maps: A Maps ToDo is not editable after Closing the ToDo
    • Maps: Export fails for imported features which do not have geometry information
    • Maps: Error "Looks like Trimble connect servers are down. Please try after sometime"  comes when multiple files are attempted to view
    • Maps: The next field gets appended in the preview once the field before is deleted in the template
    • Maps: "No geometry" count is displayed for the layer used from Template library.
    • Maps: The collected feature is not seen after switching between the workspace
    • Maps: Error 404 or 400 is seen in TF app when collecting the feature in Draft state.
    • Maps: Import icons are not fully selectable
    • Maps: Template library should not show templates already in Workspace
    • Bug in conversion .obj and .stl files to .f3d: TCPS-747
    • Maps: TF Sync issue when using the same layer multiple times from Template library.
    • Linked layer is seen selected after opening the Templated library.
    • projects created during ecom off is shown as locked once the ecom is made on
    • Objects created by Automation script doesn't show in global search.
    • Export Activities to Excel : Hyperlinks in the exported excel is not correct.
    • Attaching files to ToDo does not change ModifiedOn timestamp
    • Maps:Thumbnail Preview is not generated when layer linked to new workspace.
    • [Caching issue] Translation issue on project template
    • "Workspace already exists" error is thrown even when no other workspace exists with the same name
    • Alignment issue in Datum filter text box
    • P11 - upgrade popup should be seen for invited user when free project limit exceeds max storage
    • [TC SDK] JSON file is being truncated
    • Occasionally it is possible to create a duplicate subfolder with the same name: TCPS 679
    • TCPS-681 Folder items in Object Sync API response are not ordered by time
    • Change response msg for duplicate folder with no access permission
    • [Share Data] Adding comma(,) in the description take the cursor to the recipient field
    • Restored map workspace doesn't land in correct workspace instead it redirects to the default workspace after throwing error
    • Maps: Form rules, check box not saved
    • Template editor jumps back when Choice data type selected
    • Maps: Inconsistent date formats
    • Load Test Issue : Slowness observed in AP POD (both Private and Public APIs)
    • [Activity] Project activity is taking much time to load
    • Deleted thumbnail download failed :TCPS(711)
    • Multipart upload API should be supported for embedded files as well (TCPS-710)
    • [public links]file thumbnails are not seen in emails When sender shared no access files to the user
    • Maps: loss of connection to server should not result in projects being unassigned
    • Maps: Required accuracy message shows at the wrong values
    • Harmonize settings: Update BE code for Custom Report export, to provide support for full set of units & precision
    • [TODO] Emails not sent for the assignee on a ToDo
    • Maps: Features should be grouped by layer and geometry type in selection window
    • [Data] Duplicate folders created incorrectly
