View Entry
Back to Library
Trimble Connect for Browser 2.61 & 2.62 | Release Notes | Dec 7 2017
Recommend
12-07-2017 17:59
Karthik Rajagopal
This is a minor release focused on improvements and bug fixes only.
Improvements
Replace attachment icon with paper clip icon
Check Box-sizing Reset
Make column resize invisible to the user on the Connect Pages
Checkbox sizing throughout application
Release - Add 'multiple files' to folder from release
[TEAM] - Sorting lists across team page alphabetically
[HTML/CSS] - UI - Move Main navigation to the left of the Project screens
[TEAM] - Change in autocomplete field per design
[TEAM] - Rearranging and style changes to buttons in teams page
MAPS - Utilise title field in Todos for TerraFlex and Map Viewer
[Maps API] Validate ProjectId in the Shared link workflow
TEAM - Navigate to team page with User ID passed through
[Maps] Performance : Layer library taking long time(more than 1min) to load all the layers in the panel.
TEAM page wrapup - Invite button
Reduce Space between the items listed in the Left panel in team page
[3D viewer] Model take long time to load
Add SyncsessionId to Files download api
Load Testing needs to be automated and should be part of the process.
Add view group support to Object Sync API
Assimilation complete but triangle count and thumbnail not received in object sync
Bug Fixes
Activities are not fetched accurately for Todo view added and Todo view removed filters
Get Childern API (both Public & Private) for root folder - Response Range header is wrong when the bcfzip file is uploaded into the root folder
Public API : Object Sync API does not retain hidden param value
[Create Project API] Internal Error is seen when the required parameter(name) is not given in the request body
Receiving a daily digest for projects, where no activity has taken place
Download activity by user is not listed for a folder containing a no access sub folder
API - Getting rollback exception intermittently when we do multi folder permission
Object Sync API returns incorrect file/folder structure
Views2d: patch call is successful when given reserved names and un allowed symbols in name field
Random failures on multi-part upload
[ToDo] Special character display incorrectly in Todo assigned name
V2 API : Create todo with negative integer in percentComplete field throwing Internal error
Public API : Tag APIs response does not have 'versionId' field
V2 API : In the response of Create todo with all params, modifiedOn param is less than the createdParam
Session not shared between browser tabs
Count of Todos is not displayed properly, when Restricted Todo visibility is ON (Due to BCF import)
Public API : Upload File API does not throw error on invalid values for hidden Param
Folders are not enumerated in full on a first fetch from ObjectSyncAPI
User from the group to which the TODO is assigned is not able to remove file in the TODO
Same company displayed thrice in site admin page while searching with domain name
Field processingNotifySet is not returned always & it has a typo error
Todos: Todos comments are filtered but todos aren't
Data Explorer : As a Project User, getting internal error while trying to sort by "Last modified by" column
Profile : Changed user name is not getting reflected during next login
Files cursor is affecting thumbnails ObjectSync response
Sending parallel GET requests fails
Object Sync API returns cumulative info for Tag object
Response code for Get Group Details API is wrong
INT Env : When opening a connect tab in a new tab, get a no-access page
Public API : Upload File API does not throw error on sending other fileId in IfMatch
Release object dueDate is occasionally incorrectly considered invalid on Release creation
Move & Replace - Issue when replacing a file from parent to child
When assignee is removed form ToDo, email subject and content is invalid
Team Excel Import depends on active session of user who uploaded the excel
Status value in ObjectSync and heartbeat for files occasionally different without reason
For a 2D view which is renamed, latest name is displayed in the view created activity
Object Sync support is missing for trianglesCount information
views 2d api - assigned user cannot assign a 2d view to another user in the project using multipart patch api
Public API : Create Release API failures has effects on Get Project Status API
todo :User should be able to remove attachments from todo if todo is assigned to him
Public API : Object Sync API FileDTO does not contain checkedOutBy and checkedOutOn params
Public API : Object Sync API createdOn wrongly maps to modifiedOn value
Callback fails in Embedded viewer for non US pods
Public Data Share Email from Macaw User to anonymous user : Content in English instead of Japanese
User is able to share No access/ReadOnly files via API
Public links : New lines(added notes) are not reflecting in the mail
Clashsets "ignore clash within the same file" rule isn't working correctly
[Share Data] Sharing the link gives"Invalid session" error
Asia Pod - Map workspace Public sharing is not working for Asia pod; "Unauthorized user" error is showed on hitting pubic share URL
Falcon/Macaw : 3D machine data is not downloaded when time and date is set to past dates.
[Views] Saved view display incorrectly in viewer
[3D VIEWER] Unable to zoom to exact level in a model due to improper mouse sensitivity
3D viewer : Created clashset is not seen in clashset left panel after we reset the alignment
Triangle count property does not work for some file format (skp)
[BCF] Exported bcf link only snapshot to the todo
Cannot get clash items
Project details : start and end date values are returning previous day values after user edits it
subscription api- 400 bad request error is seen while clicking map work space, create 3d model options from excluded projects
[IFC] files failing to process
[BCFZIP] BCFZIp file not processed and ToDos not created
[Views] Saved View Shows Different Mashup From 3D Viewer
[REPORTS] Report generation failed for an IFC file
Clashsets dont find clashes correctly in Europe servers for some project
Setting alignment sets it for first file version instead of latest
Share data : forbidden error is seen for a file while opening shared links from different pods
Latest clash name is not displayed in clash deleted activity
[Public links] Exception is seen in UI when we click the download link of the revoked link
share data : latest revision is seen instead of specific revision during share edit
BE - If we change alignment of 1 revision for 3D file, changes are reflected in other revisions also.
Thumbnails heartbeat not changed after assimilation complete
Symbols in filenames should not be encoded while downloading
[View] Model not showing properly in Viewer mode
Production assim workers errors: AcmeCADEconverter fails to generate pdf and image file
I can upload files to the project, but when trying to restore file from Activity, get "Storage maxed out" warning
Clashset : clash count is reduced when clashset is created after realigning the model.
[Share Data] [EU] Download button not available on the public link file which has 'View and download" option
Tag object has different timestamp properties (CreatedOn, ModifiedOn) in creation response and object sync
Old path is retrieved by search API even after the folder in the path is renamed
[ASSIM] 3DModel Not Displaying Correctly
Inconsistency in ObjectSync response for deleted links
[Views Parity] TCW always display default text markup color.
[Public links] When we download a file from mail after shared file's revision got updated. It still downloads the the old version
Getting permission denied error when opening released file which is no access 3D file and renamed/restored
[ASSIM] Some surfaces of Rhino model show up incorrectly
HT cursor goes back in time
iBug - Crash observed on loading 2 models simultaneously
share url information is missing in the doc
Public API : ListBimObjectsInFile API does not throw error on invalid values for isInternal Param
Maps - Thumbnail is empty in the public share email
Shared Clarity presentations are missing image
[Public Links]: Image upload failed in profile page when user goes in as registered user mode
[Team] Error is seen when inviting multiple users to a new project - Intermittent
[Data] Folder size is incorrect
Issues found by Permission test automation
[Data] Folder showing 0kb size but it has some files
PDFGenerator is causing scheduler worker OOM issues in Prod EU
Projects :Sorting is not working correctly for Last modified column in project dashboard
[3d] [IFC] Floors aren't visible in the viewer
[BE] public links : Upload is not happening when a no access/ read only file is shared to the user
[3D VIEWER] DWG file not assimilated
[3D VIEWER] IFC Files are assimilated, but not displayed in 3D Viewer
[500mb] IFC file failed processing
Public API v2.0: Validation for filter (Optional) parameter in getProjectSettings is not handled.
No Instant email sent for Comment added/edited/deleted for any view
jboss Full Garbage Collection and OOM incident in Prod US
[Bcf Import] Selected Element in Tekla BIMSight is not shown in TC
Releases sent to group are filtered incorrectly when CreatedByMe/ModifiedByMe/SentByMe filter is selected
[PROFILE PAGE] Users unable to complete Profile as 500 Error
[Mashup] Mashing Up 12 Models or More Actually Shows 11 Models
[Maps] When 'Hide data layers' option applied, only updated forms selected
[Maps] Problem with clustering in Task view
FE - If we change alignment of 1 revision for 3D file, changes are reflected in other revisions also.
BUG-3D View not loading from todo when opened in new tab
[QA] Harmonize unit settings ft-in conversion
Share data:Getting compatibility error for shared DWG files while assimilation is in progress..
Share data behavior - for email IDs outside project members group
[LANGUAGE] Incorrect French translations
Add Files to ToDo : Get ToDo API is called more than once when there are more than 25 todos in the project
[Maps]Forms API returns incomplete dataset when using ScrollID
Both From Date and to date fields need to be populated while clicking today/ past 7 days / past 30 days links
Maps - Extra blank space in observed below offline base map list in map workspace
[Maps] Export tag should be removed from a form when an update is received
[Maps] You need to manually refresh the map viewer to see if a file has failed assimilation
FE : ES Breadcrumb/Permissions - Spinner continues to spin
Maps: "No existing layers/template found" context prompt is not seen when search result is empty.
[Maps] Published Collected/Updated fields show 'true' and 'false' instead of actual setting value
[Team] in Team page user list loads twice when switching between the views.
Error is seen when Importing the exported data in a map workspaces.
[ArcMap Plugin Integration Issues][Form Service] Form bulk POST/PATCH APIs are not taking FormId
[Maps] Template editor: imported fields default to required
[MAPS] VCE file is not assimilated
User is navigated to Project page after clicking on remove button in Team users details panel
[Maps] Change wording ‘No existing Templates found’
[Maps] Status bar changes to square shape when closing the Todo
[Team] "No results found" message is not seen in user details panel.
[Maps] Only during first time Error 404 or 400 is seen in TF app when collecting the feature in Draft state.
[Maps] TerraFlex cannot connect to Connect Maps on phones using Android 5.0.2 or 4.4.4.
MAPS - Feature panel loads before check for permissions
[Maps] Task complete status for the feature is seen when Data panel is selected.
Right Panel issues in Team page
[Maps] Layers are duplicated or odd - Intermittent
[Maps] Linked workspace count not updating correctly
[Maps] Import fails for certain formats
Team: "Empty_String" Error is seen when inviting the users using double comma.
Not all offline base maps are syncing with TF app
[Maps] Attached shapefiles fail to assimilate
[Maps] Only one feature should show teardrop marker
[Maps] Filter by exported is not showing the exported feature until a manual refresh
TF app crashes everytime when launching the app in Redmi note 4 device.
[Maps] Forms should be displayed using the template version they were collected with
Team: Add button acts inconsistent and Unchecked user is seen in invite user dialog.
[Team] In IE the role name for the user is not updating without manual refresh.
3d viewer : cannot scroll till the end of the model tree
Angular : Auto list should be turned off for due date and name fields
Activity : Edit activity icon is missing for todo's title,completion, view update and type activities
User profile api is called every time before project membership api is called.
2d viewer : Revision 2 is seen selected but the actual loaded revision is the first revision
Profile :while changing the language preference Job title goes blank until we do a page refresh while changing the language preference
Todo : permission denied error is not seen when unshared clash items are added to todo
No error message is displayed in UI for a user in todo/activity page of the project, when the user is removed from that project in another window
FE - Tags : Tags should not accept OS Unsupported characters as tag name
[ACTIVITY] Edit button doesn't work on the activity for the files shared with a group
#clashes column header alignment is too far away from values
[Macaw] :Labels seen in object linking dialog should also be changed.
Object linking : "Add attachments from Link" seen in the links section needs to be modified
[3d viewer] Moving for second section works differently
Todo : cursor goes to assignee from tags field while pressing enter key
[Projects]:No Error message is seen when uploading larger sized images in New project creation.
Tags : tags are not added when there is multiple selection of objects
Creating project from existing is taking start date and end date as same when not selected by user
[Public Links]: Get started and Sign in buttons colours are changed.
Lock icon on project overlaps with project icon
Appropriate error message is not seen while updating the implicit todo
Model is not rendering in windows 10 - chrome version 60.x.x.x
Dialogs : Submit is not changing to working in few dialogs
Model thumbnails attached on clashset flickers on load
3D viewer - Breadcrumbs - Mouse hovering hides heirarichal folder name
3D viewer- Model Tree - IE10+ Support - Resizing panel is inconsistent
Activity - Text change while adding files to todo
Release is not seen selected in release page when it is opened from activity page
Activity : Default svg image for share is not seen in activity page
[Project creation] Clicking on i changes the POD preference
Site goes down even if one POD is down: Issues left
[Activity] [ToDo edit] Icon missing if make changes for ToDo type
Todo : Along with permission denied message, internal error is seen when user try to remove tag created by admin
Model refreshes twice when opened from todo page
Due date based filtering mechanism is wrong for todos
Object Not Found error is seen when user selects full access folder
removing duplicate calls(breadcrumb) in data explorer.
Project : "The value entered is not valid" message comes at the top left corner of the page
Folders : Getting Permission Denied for all the folder operations after giving full access to the restored folder
Error banner.html is seen whenever projects are loaded and project is opened.
Autocomplete text needs better formatting
Unnecessary redirection to data page while clicking on inaccessible 2Dview attached to todo
Restrict Compliance incompatible characters on signup
Comments : Comments which were added for older revision is seen in data page but not in viewer
Tapping on no access folder from breadcrumbs (Accessing via search result), keeps page loading after throwing permission denied error
[Team] Incorrect string is seen under add group input box.
[Maps] Choice field is not getting focused in layer to template creation
