View Entry
Back to Library
Trimble Connect for Browser 2.64, 2.65 & 2.66 | Release Notes | Feb 15 2018
Recommend
02-15-2018 18:13
Karthik Rajagopal
This is a release focused on improvements and bug fixes only.
Improvements
Performance Improvement: C
hanges for faster querying with Read replica
Performance Improvement: List Items in a Folder [GET]
Performance Improvement: List Items in a Folder by path [GET]
Performance issues when clicking on a locked project
Improve Performance of List Groups in Project
Improve 3D view loading time after initial load by caching bsq chunks
Thumbnail Slow query in object sync
Share Data: Fix viewer licensing error
License enforcement API response improvements
Updating settings does not modify project's ModifiedOn property
ToDo Assignment email content needs to indicate there more files linked to a ToDo
Add usersCount in the List Groups in Project
Add filters to the release files tab
Checkboxes styling with background images
Standarisation of dropdowns
Browser Support Notice
UI - Apply flex box - Data List view
UI - Apply flex box - Clashsets List page
UI - Apply flex box - Todo List page
UI - Apply flex box - Views List page
UI - Apply flex box - Add files to Todo list dialog
UI - Apply flex box - Add files to Release list dialog
Change date pickers to icon instead of arrow dropdown
[TEAM] - update filters on add/remove/edit users on new filters
Implement project placeholder thumbnail
UI - Align the file tile layout with the tiles defined in the team page and project list
Update the project tile and project listing display
[Map] Zooming lost background data
[Team] Correcting alignment of text in 'Company', 'Role' fields in right panel
Views Parity : Hierarchic object hidden
Units strings : Multilingual support
Give visual importance to upgrade buttons
Custom report parameters for Area and Volume
UI - Buttons standardised against the styleguide
[Maps] Radio buttons and check boxes aren't shown beside Choice field values
Share Data: UX improvements
UI - ECom: Providing project access to a user with any license and Project's License drives the enforcement
Invite on others Free project - apply project's license
[Maps] Better handle syncing of deleted template
[TEAM] - Allow filtering of users by status,groups and roles - part 1
Show more user friendly message instead of "DEFAULT_ERROR"
Bug Fixes
Tag search not working for capitalized tags
usedProjects should have updated value in the response of createProject call
[TEAM]:Public API Invite user not accepting 'groupId' parameter
Used Storage is not updated when a file is deleted
Comment for Clash is not displayed in ObjectSync
Public API : Update File API does not update modifiedBy
Clashset : clash count is reduced when clashset is created after realigning the model.
RVT File failed to assimilate
Revit file assimilation issue in TC Mobile
Navigation inside the non master POD projects are slow with ecom ON
Free project allows more than 10GB
4 dwg files and 1 skp file failing assimilation
User with ATC license only shows Free account also in the license api
For ATC license MRP flag should fetch from DB
Upgrading Free Proj to Biz Proj - INTERNAL_ERROR: java.lang.NullPointerException
usedStorage is not reset to 0 for a recreated free project
[Project Template] Not able to delete folder in the new derived project
BCF generated todo increments label number by 2
Empty/ null values seen on right panel while renaming clashset
Some of the files and folders are not downloaded for the user when downloading root folder
[3D VIEWER] DWG file not assimilated
BE - If we change alignment of 1 revision for 3D file, changes are reflected in other revisions also.
User activity email shows username multiple times
Removing ecom exclude for a company does not remove exclusions applied for the users in the company
Invite on Free project is not allowed , if the free user is changed to Biz user or excluded user
Project count mismatch on reassigning project license
Storage Maxed out error is displayed for Business user in a Business project
Project Creation in Non Master POD is failing with Internal Error
Able to create more than 1 free projects, in different PODs.
usedProjects count is not updated for licensed user when a project is deleted
3D View : Markup is not displayed on clicking unhide markup icon
[Maps] Geo files assim is failing for certain formats in stage and Prod
[UI] Please select Job Title not translated
Getting console error while mouse hover the clashitem in right panel
Japanese Translation Issue in the FOLDER PERMISSION
[Webapp] Walk mode shortcut key
Clash : Clash Items selection is not retaining once model element gets selected
[Maps] In Asia pod "No previewable data" is seen for the assimilated files.
Invalid characters shown in Compliance page error on entering invalid pincode
[Team] "Back to team list" string is seen at bottom in User details right panel
[Team] Centre panel is not getting refreshed once role of the user is changed when the filter is applied.
Some of the Profile page fields are not mandated
[Maps] Exports and not exported filter acts incorrectly
3D Viewer: Hiding/Unhiding the model does not work properly for the elements which are hided/unhided individually
[Maps] Console error is seen when navigating to template editor page
[Team] Create Group button is seen for the user having user role in the project.
[Team] Group Deleted notification is seen in yellow background.
Continuous loading worm is observed in filter panel (User section) of shared map URL
Invite on Free Project - Upgrade button take Excluded and Business User to /tc/false page
View button in the right panel is not clickable when clicked outside the "view" text
