View Entry
Back to Library
Trimble Connect for Browser 2.67 & 2.68 | Release Notes | Mar 22 2018
Recommend
03-22-2018 17:14
Karthik Rajagopal
This is a release focused on improvements and bug fixes only.
Improvements
Tag search optimization
Project listing performance optimization
Server and DB performance optimization (Continued)
Performance improvements - DELETE file Api
UI - Apply flex box - Team list view and Search result
Excel Import with non English characters in filename
Users list Public API - option to exclude remove users to be introduced
Improve rendering of measure with pick.
Add view group support to Object Sync API
ToDo list for Japanese Translation fix
Enhance responsiveness in the Connect application
UI - Align the file tile layout with the tiles defined in the team page and project list - Styling
Fix "HTTP Status 400 - Bad Request" error when email address of users is changed
Bug Fixes
Error processing an IFC file with more than 800mb
Thumbnails stream returns data when it shouldn't
Wrong thumbnailUrl in response on file upload
Team import fails with "error performing isolating work"
Saved Markups not visible on View/ToDo
[Share Data] Download All does not download the files from email when there are more than one file shared
[3D VIEWER] IFC file assimilation error
ToDo Bulk Edit takes very long time when updating Tag
For free and excluded projects, the billing account in settings page is not shown properly.
Setting alignment for latest file version changes alignment for previous version
View group isn't shared correctly for same user on different machines.
Multipart upload disregards "Require file checkout before being able to upload files" option
Tags which are added are not saved to objects consistently. ES Tag Index performance Improment
Excel file fails processing
Public API thumbnail URL is required for View(Both 2d and 3d) and ToDo attachments in object sync response
Large (more than 1 MB) 2D file (xlsx) is not getting processed
Apply filter on tag search
Views(within view group) that are shared are not listed inside view groups
Attachments added to BIM objects in TCD are not displayed in TCWEB
Exception handling during Bulk indexing
[PROJECT] Old project users receive email updates for new project template
Issues are observed when adding another version of renamed checked-out file
[Project Specific] "This folder is empty" is shown even if there are folders in the project
File isn't shown in the folder of project
Get File Details private api causing too many transactions when the files has many versions
Projects List is non transactional causing too many transactions
"Object not found" error is thrown when new version of checked out file is uploaded after renaming/ moving to another location
Object links created in Web are missing type property in the source
[Team] Group count is not getting refreshed.
line spacing and alignment in update message is odd on different screen sizes.
ToDo : 2 implicit views are attached when clashitems of same file are added to same ToDo twice
Model tree elements on left panel do not get highlighted on selection
[Team] Folder icon is seen in when selecting multiple users.
[Team] Selecting tile view the user are not listed in the Team page.
