Trimble Connect for Browser 2.70 | Release Notes | May 30 2018
05-30-2018 23:48
Stories
  • Remove Rhino translator from TC (license compliant consideration)
  • ProjectDetails- Public API migration
Improvements
  • Performance enhancement for Tag Search
  • Improve Performance of Slow redirect during SSO logout
  • Improve Performance of Thumbnail Object Sync calls
  • Get File details : Migrate to public API in TCW : as private api is slow for the file which has many revisions
  • Create project API performance improvement
  • FSObject Stream - percentage calculation
  • ATC license users see their project locked intermittently
  • Reduce multiple listing calls in 3d viewer - collapsing the filter node should not trigger API calls
Bug Fixes
  • User removed from assignee loses access to clash even if he's part of a shared with group
  • Releases : modified by is not updated when another user add/remove a file to the release
  • ObjectSync is reporting wrong CreatedOn for deleted or modified files
  • File status displayed incorrect
  • Production Performance Incident: potential issue with objectlink; strange CPU/thread behavior
  • Assimilated IFC file not rendered for 3D Viewer
  • Todo : Unable to remove a todo when assigned group is removed from the todo
  • Previously indexed items are not returned in tag search
  • API : Cannot add attachments if the todos are assigned to a group
  • Email domain changes using Site admin are not synchronized to non-master pod correctly
  • TDS integration: Wrong project id on queue job when deleted file is restored
  • [Project Specific] Thumbnails are showing for failed files
  • Inconsistency in excluding and assigning license to user/project/company from site admin page
  • Excluded user was included (licence check enabled) again after exclusion
  • Alignment sync stream paging loops forever
