Novapoint
"WinRit" does not start
05-24-2021 01:18
When installing Novapoint GeoSuite Toolbox - always run the Setup.exe file - Do Not use the "msi"-file!
Running the "msi"-file will not install the 3:rd party component used for WinRit. This will cause an error when trying to plot profiles and produce PDF-files for boreholes. If You have run into this problem - restart the Install process by running Setup.exe and select "Repair".
