Quadri
Workset CRS
03-28-2021 19:56
MOUS_ICO Models > Select Model > Modify > Workset CRS
If you click on a model in the model list and select Modify and Workset CRS, you can add or remove coordinate reference systems that the model can be downloaded from, for example, Novapoint.
If the model has a compound storage CRS, the first step of the wizard will be to select a list of compound workset CRS. Check the compound workset CRS in the list in which you would like to receive your data when you download a workset from a model in Novapoint.
In the next step, check the projected workset CRS you want. If you have selected one or more compound workset CRS, you will not be able to uncheck the corresponding projected workset CRS.
In the last step, check the vertical workset CRS. If you have selected one or more compound workset CRS, you will not be able to uncheck the corresponding vertical workset CRS.
Click Update Workset CRS to save.
