View Entry
WorksOS
Civil Construction & Infrastructure Solutions
Back to Library
WorksOS Release Notes - November 2021
Recommend
11-02-2021 14:45
David Kosakowski
New & Improved
This WorksOS release includes these new features and enhancements:
Map View/Graphics
Performance improvements - Map screen ‘Composite Tile’ improvements have been deployed so the Map page now loads all data types much faster and with improved responsiveness when you toggle data types on or off. These enhancements include faster uploading of Pass Count details and Quality Metric tiles on the Map screen.
Settings Menu Interface
New Settings menu icon - Settings are now available via a new cog icon that allows you to directly access WorksOS settings from all areas (Dashboard, Map, and Progress Volumes pages).
Status Notifications
New Notification icon for Imports, Exports, and Reports - Each time a file is imported, or an export or report is generated, WorksOS now tracks the progress of the process so you know if your file is still being imported or if you are waiting for an export or report to generate. The notification icon will also indicate if an import, export, or report fails.
Excluded Elevations
Exclude data outside of an elevation range - You can now use an Excluded Elevations filter to specify the valid elevation band for your project. Machine data with elevations above or below this range will be excluded from calculations, which can help improve the accuracy of your material volumes. Filtered data is not deleted from the model and can be retained or recalled. For details, see the help thread/document called Apply Filters and Analyze Metrics in the WorksOS Resource Center. See the demo video here.
Detailed Data Viewer (DDV)
List Surveyed Surfaces - The DDV now lists Surveyed Surfaces along with Device Productivity Data. When you profile a cell containing a Surveyed Surface, you will see it in DDV, including the date/time of the surface and the surface elevation reading for the selected cell.
List Machine Mapping Mode - The DDV now lists the Machine Mapping Mode that a machine is reporting in as, e.g., “Latest Pass” (GCS or Earthworks machines) or “Minimum Elevation” (Earthworks machines only).
Fixed
WorksOS also deployed fixes for reported or discovered cases in which:
Drone Orthophoto files contained white or black squares overlaid on the map. You now see only the drone imagery (the white/black squares are no longer visible, allowing you to see through to the background map).
Japanese translations were not optimal; corrections have been made.
1 Files
16 Downloads
Attachment(s)
WorksOS - November 2021 Release Notes.pdf
1.80 MB
1 version
Uploaded - 11-02-2021
Download
Download Document
Please accept the terms of the copyright associated with this attachment before downloading it. Click the link below to read the terms.
Accept
