Trimble Connect 3D Viewer 1.0.133 - Release Notes - Nov 03, 2020
By Jari Juntunen posted 11-03-2020 08:58
Nov 03, 2020
Trimble Connect for Browser 3D Viewer
v1.0.144
Improvements
Today we launched a new version of the Trimble Connect for Browser 3D Viewer, available at  https://3d.connect.trimble.com. This update introduces the new perpendicular measurement tool toolbars.
  • Use the perpendicular measurement tool to quickly take shortest perpendicular distances between points, edge lines and object faces:
  • When starting the perpendicular measurement tool, the new toolbar allows choosing the snapping preference (snap to points, lines, or faces):
  • After the measurement has been created, the new toolbar allows choosing the alternate X / Y / Z dimension, switching direction, hiding units or changing the color of the measurement
    (Note that making the above choices is only possible before the measurement/dimension is saved into a view)
Bug Fixes
  • Views are not created for the .trb file format.
  • Bug in viewer resetting color and visibility should now work properly
  • Translation issues with Dutch, German, Norwegian and French languages
  • UI issues with the property of the object
  • Attachments panel loading issue: not all attachment has been loaded
#Trimble_Connect #Trimble_Connect_Browser #3D_Viewer #Release_Notes #Product_Updates​
#Trimble_Connect_3D_Viewer
0 comments
