TBC Macros and Extensions
Corridor Cut Sheet TML
By Peter Kistler posted 10-07-2019 14:12
The Corridor Cut Sheet Report is a Rockpile Solutions TML created to provide cross section based reports for corridor models for use by field staff as a way to check and validate highways construction. The report will generate a node list at defined corridor stations; split into Right Side and Left Side nodes ordered from Centerline outwards; and display the information in a compact or fully detailed format.
Corridor Cut Sheet TML screen snap
Command documentation is at https://rockpilesolutions.com/files/Documentation/CorridorCutSheetReport.pdf
If you would like a trial version of the TML, email Peter@RockpileSolutions.com
Corridor Cut Sheet can be downloaded, installed, and updated using TMLStatus
0 comments
