It can be useful sometimes to improve TMC 2D display performance or for Restricted Area vessel outlines to use a 2D Vessel Countour instead of the full 3D model of the vessel.
To do this quickly without any manual entry:
- Open the 3D model in Sketchup
- Set the Camera view to Parallel Projection
- Change view to be from the top, select the model and export 2D Graphic as DXF
- Repeat for left and rear camera views.
- In TMC create a new Vessel Contour and Edit
- In the Vessel Contour editor click in the 'Top' pane to make it Active then use the Import from DXF to select the top view created from Sketchup
- Repeat for the Left and Back panes
- Use SHIFT +Left Mouse on gripper to move the model onto a different origin if required
- Save on exit
#TMC
