Hi Lane,
thank you four your reply. Yes we have activated "Share Location" on TrimbleMobileManager.
I do not have the permission to view this blog post. Is there any possibility that I can view it?
Best regards,
Alex
Alexander Klausegger
Sent: 08-31-2021 08:09
Subject: Re: TDC150 and ESRI ArcGIS collector
Hi Alexander,
In partnership with ESRI, we have developed a fix for the issue you are referring to. Can you confirm you are using the "Share Location" method of providing the Trimble GNSS location to ESRI Collector that is required for the solution to work as expected? The details of this solution and steps to set it up can be found at the post Update: Collector on Android 6 hardware with Trimble receivers (e.g., TDC150/SP20).
Lane Carter
Sent: 08-31-2021 00:24
Hi Mark,
could you tell me about the status of the discussion with Esri about the issue of the Collector app (Aurora) crashing when using TDC150?
We are using ArcGIS Collector (Version 20.2.2) on a Trimble TDC 150 device with Android 6.0.1 and the Collector app crashes everytime when starting Collector and trying to sign in to ArcGIS Online.
I have found the following BUG-ID where it is explained, that the issue was found in 20.2.1 and implemented in 20.2.2:
https://support.esri.com/de/bugs/nimbus/QlVHLTAwMDEzMzgzNg==
Nevertheless, the problem also occurs in 20.2.2?!
Using Field Maps unfortunately is not an option.
Best regards,
Alex
Sent: 09-23-2020 14:12
Hi Jim,
Currently there is a technical issue when running Collector Aurora which results in a crash. As Matt has previously indicated, we are actively working with Esri to address this issue and expect positive news on that very soon. We will keep everyone updated as soon as that happens.
Best Regards,
Mark.
