Following this thread to see how this correct. I did do a sampling distance override in the corridor template setting and had several flags get removed. I exported the surface and reimported the surface. Looked fine.
roundabouts, never had issue as I closed short from the star of the alignment. I also use 3D lines to create my corridors by means of the SIDE SLOPE tools.
Francisco Guerrero
Sent: 03-23-2023 12:53
Subject: Closed Loop Corridors
Thanks for the tip, let me try to shorten the last segment
Adam Bower
Sent: 03-23-2023 07:46
The easiest fix is to just shorten the last segment in the alignment by 0.01 ft. (so it's not a closed alignment)
Plan B would be to put a null template near the end of the alignment.
Gary Lantaff
