Surface adjustment
  • 1.  Surface adjustment
    Posted 10-02-2022 22:49
    No replies, thread closed.
    I have a surface generated from a Point Cloud (or even otherwise).
    I have a set of non linear points within the above surface with 3D values (Easting, Northing, Elevation).
    Is there some way in TBC to adjust the available Surface to conform to the set of points? A 3D Planar Rotation / Translation Adjustment may be, even if approximate?
    Any suggestions outside TBC?
    Thanks.
    Saif Bin Darwish
  • 2.  RE: Surface adjustment
    Best Answer
    Posted 10-04-2022 02:51
    Hi Saif
    I would recommend you post this question in the Trimble Business Centre community for the best chance of a response.
    The MGIS community here focuses on the MGIS Data Collection & Integration solutions within the Geospatial portfolio. This does not Include Trimble Business Centre unfortunately
    I'm sure you will find help If you repost this
    Tom Harrison
