Novapoint Landscape Library
Add Point Elevation
04-07-2021 19:43
Use this tool to calculate the elevation for a new point elevation based on the distance between 2 or 3 reference points.
MOUS_ICO Menu: Landscape > Elevation tools >  Add point elevation… MOUS_ICO Toolbar: Elevation tools:Add point elevation…
Working procedure
Start the function and the command prompts:
Select first elevation block:
Select one of the elevation blocks from which the new point elevation should be calculated
The command prompts:
Select second elevation block:
Select the other elevation blocks from which the new point elevation should be calculated
Specify basepoint or [Third]:
Set out the new point elevation. Use the given distances from the reference points to define position of the new point elevation or use option [Third]:type ´T` and select a third point elevation. Set out the new, third point elevation, correctly calculated on the triangular plane defined by selected point elevations.
Tip: Use Ctrl-button to lock the new elevation point to mid point or gravity point on a triangular plane.
About point elevations in Novapoint Landscape
  • Point elevations are blocks with an insertion point in the “+”-sign. The z-value for the block will always be equal to the written text.
